How to reset I2C bus on i.MX8QM
1,368件の閲覧回数
xu_ji1
I want to add reset I2C bus logic on I2C driver,how to do this and does I2C bus support it?
1,364件の閲覧回数
Hi xu_ji1
as all accesses in i.MX8QM are performed through SCFW APIs, one can look at function
sc_err_t sc_pm_resource_reset (sc_ipc_t ipc, sc_rsrc_t resource)
This function is used to reset a peripheral.
described in sect.Reset Functions sc_fw_api.pdf document included in
SCFW Porting Kit​
1,344件の閲覧回数
xu_ji1
I want to reset I2C bus in kernel,  I need reset it after booting, when I2C bus init done before device register on bus,is it support?
