How to remove Bluetooth from Android build?
2,943 次查看
esteban_vazquez
I am working with Android Open Source Project (AOSP) on an IMX based board. I would like to exclude the bluetooth modules from the compilation.
I used "mgrep" to look into the Makefiles to find references to the Bluetooth but I couldn't figure out which options I need to add or remove.
I would like to know which Makefiles and config files I would need to edit. How do I remove Bluetooth from Android build?
2,711 次查看
shivanipatel
Senior Contributor II
Hi, Esteban Vazquez
You need to disable following configurations in order to remove Bluetooth Module from the Build.
  • UART interface
    • CONFIG_SERIAL_IMX
    • CONFIG_TTY
  • HCI interface
    • CONFIG_BT_HCIUART
    • CONFIG_BT_HCIUART_H4
  • Bluetooth Stack
    • CONFIG_BT
    • CONFIG_BT_RFCOMM
    • CONFIG_BT_RFCOMM_TTY
    • CONFIG_BT_BNEP
    • CONFIG_BT_BNEP_MC_FILTER
    • CONFIG_BT_BNEP_PROTO_FILTER
    • CONFIG_BT_HIDP
Hope this will help you.
Shivani
