How to read pcm data within a linux driver
1,783 次查看
andrwebb
Im trying to write my own Asterisk DAHDI driver for an si3050 on an imx6ull.
The part I currently dont know how to do (I've just gotten into driver development) is to read and write audio data to the SAI(synchronous audio interface).
I found the fsl-sai driver: https://elixir.bootlin.com/linux/v4.14/source/sound/soc/fsl/fsl_sai.c but I'm not sure how much of it I can use since I'm not making an alsa driver.
My ideal solution would be to set up some kind of periodic sdma transfer that could call an interrupt handler that will read/write the audio data and allow me to call my dahdi library functions within.
That fsl-sai driver is also set up to use dmas = <&sdma 39 24 0>, <&sdma 40 24 0>; so would there be some way to hook into those?
I notice that https://elixir.bootlin.com/linux/v4.14.78/source/include/linux/platform_data/dma-imx.h has IMX_DMATYPE_SAI, so I'm wondering if its possible to use that somehow?
标签 (2)
1,760 次查看
igorpadykov
Hi Andriy
one can look at MX6ULL FreeRTOS  examples in ../demo_apps/sai_sdma_freertos
https://www.nxp.com/design/software/embedded-software/i-mx-software:IMX-SW
