How to program DTB file only for SABRE board?
2,728 次查看
Sun1z
Is it possible to use mfgtool to program/update DTB file only to i.MX6Q SABRE board (Android M6.0.1_2.1.0 GA)?
B.R.
Sun
标签 (2)
1,784 次查看
JayTu
The device tree is part of the boot.img. You can unpack the boot.img and re-pack it with your device tree.
4 回复数
1,785 次查看
JayTu
1,784 次查看
Sun1z
Got it clear that even there is a minor modification only in dts file, I need re-program the boot.img again.
1,784 次查看
Sun1z
I checked ucl2.xml and found for eMMC-Android, no DTB file is involved, means for android, no DTB required? then how I can set the device tree.
1,784 次查看
joanxie
if you need to build kernel, you need to use toolchian, mfgtools is for download image to your board,you can refer to the document as below:
Task #8 - Build kernel manually using created toolchain
for path, you can find the dts file under:
fsl-release-bsp/build/tmp/work-shared/imx6qsabresd/kernel-source/arch/arm/boot/dts
