How to print NAND BBT from Linux on i.MX6Q?
dilip
How to print the NAND BBT from Linux on i.MX6Q to find factory bad blocks? I didn't find any options on kobg-ng utility. NAND flash is detected on boot and scan happening is successfully.
thanks,
Dilip
Tags (3)
alejandrolozan1
You can try with "kobs-ng init -v $FILE", that should dump the structure.
I hope that helps,
Alejandro
alejandrolozan1
I hope that helps,
Alejandro
dilip
Thanks Alejandro.
