How to port pin configuration into uboot and kernel ?
1,150 次查看
Jimmychea
How to port the pin configuration into uboot and kernel(eg, imx8mp-evk.dts, imx8mp-pinfunc.h) after done the pin configuration using "config tool for i.MX" in imx8mp ?
1,113 次查看
Sanket_Parekh
Hi @Jimmychea
I hope you are doing well
Please accept my apologies for delayed answer.
After generating the DTS/DTSI files using the config tool for i.MX, you need to manually merge(copy and paste) it in the actual file present in BSP in the arch/arm/dts folder.
This file is only a snippet and not a full device tree file content. There are just basic device tree elements.
For more information please refer to section 3.2 Example usage(point number 9) of User Guide for Config Tools for i.MX.
Thanks & Regards
Sanket Parekh
1,114 次查看
Sanket_Parekh
Hi @Jimmychea
Thanks & Regards
Sanket Parekh
