How to perform AT command for HUAWEI MU609 3G module
陳冠儒
hi,all:
Consult all,How to use the HUAWEI MU609 3G module to perform AT command, I can not use AT command, this command does not reply.
As follows:
root@imx6qsabresd:/# ATE0
-sh: ATE0: command not found
Explained below:
ATE0: ATE–Echo Command
Example:        Run:   ATE0
                       Response: OK
Please help me,thanks !!!
Labels (4)
jamesbone
You need to have the package from HUAWEI to allow the usage of AT Commands, please contact HUAWEI to get access to the library.
陳冠儒
hi,jamesbone:
I asked HUAWEI, FAE say they just do linux BSP original code modification can be, depending on whether you do need additional package for HUAWEI?
Please help me everyone,thanks.
