How to open .img file
3,263 次查看
zoy74758
On nxp website, I have downloaded the android image
android_o8.1.0_1.4.0_7ulp-ga_tools.tar.gz
and from there, I run script
mfgtool2-android-mx7ulp-evk-sd.vbs
To load the android image to the SD card.
I disagree with some functionality of recovery which I do not like to discuss. I just want to open the image file and change its recovery partition.
The loaded image file is
imx7ulp_m4_demo.img
But, I have no idea how to open this image file.
How is this format architected and what software should I use to open it?
3,068 次查看
shivanipatel
Senior Contributor II
Hi, david cammeron
Here from your query, it seems that you want to change something in the recovery partition of Android. But the file you are mentioning imx7ulp_m4_demo.img does not contain the information anything regarding recovery. You will get the more idea about android partition from this link.
If you want to change in recovery partition then you need to have the i.MX7ULP android source.
Shivani
3,068 次查看
shivanipatel
Hi, david cammeron
If my above posts answer your question then can we close this thread?
Shivani
3,068 次查看
Rita_Wang
You can not open this file, as Shivani told you need change the source code if you want to do change in recovery mode.
3,069 次查看
shivanipatel
Hi, david cammeron
Shivani
