How to mount FAT partition on SD card
2,234 次查看
JasonYu
Hi All :
           I am using imx53 smd board . boot up is ok .but I could not saw sd card mounted under android setting -> SD card or Photo Galaxy ? If i use android file manager I could saw SD card normally , Why ?
                                                           Jason Yu
标记 (1)
1,720 次查看
daiane_angolini
You can find vold.fstab with the following command line:
$ cd <my_android>
$ find -name vold.fstab
It´s under device tree. And goes to your out dir when you build your android source code.
1,720 次查看
JasonYu
Thanks Kevin !!
Please tell me where i cound found the vold.fstab ?
I use "mount vfat /dev/mmcblk0p2 /mnt/sdcard" in init.freescale.rc , it correct or not ?
1,720 次查看
KevinChen_ng
maybe these tips can help you:
<1> to check mmcN? your SD card has registered as.
<2> to check vold.fstab , whether your system choose to mount your SD card as sdcard or extsd?
