How to modify code and then build image?
ソリューションへジャンプ
4,305件の閲覧回数
bobking
Hi,all:
     I am a new user for iMX6ULEVK,I knew using bitbake to build image now and build successfully,but I don't kown how and where modify the source code.For exmple,I want to run a HelloWorld in the broad.Where to edit the code? And how to build this image after modification? Is there any document including those?
3,959件の閲覧回数
Rita_Wang
Hi Bob,
You can refer to the i.MX_BSP_Porting_Guide.pdf in our website.
Dan
Note: If this post answers your question, please click the Mark Correct button. Thank you!
3,960件の閲覧回数
Rita_Wang
Hi Bob,
Dan
