How to mark bad block for iMX28
1,336 次查看
liuxing
Hi All,
 Background Info:
1.CPU imx281+NAND FLASH(2048+64)
 When I want to program bootloader xxx_ivt.sb to boot area,and there is a bad block in boot area,the uut driver skip this bad block,But the iMX28 still  boot failed after power cycle.
  I want to know how the ROM code can recognize the bad block and skip it.I guess the NCB area maybe support it. I try to program 0x00 to the spare area of bad block,however the nand driver return failed.
1,301 次查看
AldoG
As specified in the i.MX28 reference manual:
ROM uses DBBT to skip any bad block that falls within firmware data on NAND Flash device.
For more detailed information please refer to the reference manual chapter 12.12.1.12 Bad Block Handling in the ROM
Best regards/Saludos,
Aldo.
1,302 次查看
AldoG
Aldo.
1,280 次查看
liuxing
Hi AldoG,
Thanks a lot for your help!
