How to load kernel and rootfs into QSPI Flash in I.MX8MPLUS
208 次查看
Sunil_13
We are Using I.MX8MPLUS Custom board. In our board we have QSPI flash with 32MB size. Up to u-boot Successfully booted in QSPI mode .
1. How to load kernel and rootfs into QSPI Flash in i.MX8MPLUS.
2. In our i.MX8MPLUS Custom board we don't have supported devices like eMMC, SD ,Nand and USB. without all these how can we load the kernel and rootfs.
3. Is there any Procedure for loading kernel and rootfs into QSPI flash without the SD card and eMMC.
6 回复数
154 次查看
Adele
@Sunil_13
You can check the following link, it might help you.
And I have sent you about this in private message to you.
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/all-bootloader-device-tree-Linux-kernel-...
160 次查看
Bio_TICFSL
# How to Load Kernel and RootFS into QSPI Flash on i.MX8MPLUS Custom Board
Based on your custom board configuration with a 32MB QSPI flash and no eMMC, SD, NAND or USB devices, here are the recommended approaches:
## QSPI Flash Boot Solution
While your U-Boot has successfully booted from QSPI, there are important limitations to consider:
1. The 32MB QSPI flash is typically not large enough to hold a complete Linux rootFS. QSPI flash on i.MX8M Plus is primarily designed for storing U-Boot/bootloader components.
2. A practical approach is to implement a hybrid solution:
- Store U-Boot in QSPI flash (already accomplished)
- Store the kernel and device tree blob (DTB) in QSPI flash
- Implement a minimal initramfs for basic functionality
## Implementation Steps
1. Generate the QSPI bootable image using the imx-mkimage tool:
make SOC=iMX8MP flash_evk_flexspi
2. Create partitions in QSPI flash with approximate sizes:
- U-Boot: 512KB (already flashed)
- Linux kernel: ~9MB
- Device tree blob: ~64KB
- U-Boot environment: ~64KB
- InitramFS (minimal rootFS): ~22MB
3. Configure U-Boot to load kernel and DTB from QSPI flash:
sf probe
sf read ${loadaddr} 0x80000 0x900000 # Read kernel from QSPI
sf read ${fdt_addr} 0x980000 0x10000 # Read DTB from QSPI
4. Create a minimal initramfs with essential tools and utilities that will fit within the available space.
5. For more complex applications, consider implementing network boot support (NFS) for a full rootFS.
This approach provides a viable solution for booting your system with the existing hardware constraints.
152 次查看
Adele
@Bio_TICFSL
Did you delete my first reply? If this happens again, I promise I'll post this on Twitter.
124 次查看
Keta_S_Nitsure
@Adele If what you're saying is true, that's unbelievable.
93 次查看
Adele
@Keta_S_Nitsure
This is real. What I really don't understand is what was wrong with my reply. After my reply was deleted, @Bio_TICFSL  posted a very similar solution, which is technically the same. I still don't understand why @Bio_TICFSL  would do this.
150 次查看
Adele
@Bio_TICFSL
Please confirm this is NXP account in X.
%3CLINGO-SUB%20id%3D%22lingo-sub-2254333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20I.MX8MPLUS%20%E4%B8%AD%E5%B0%86%E5%86%85%E6%A0%B8%E5%92%8C%20rootfs%20%E5%8A%A0%E8%BD%BD%E5%88%B0%20QSPI%20%E9%97%AA%E5%AD%98%E4%B8%AD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20I.MX8MPLUS%20%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E3%80%82%E6%88%91%E4%BB%AC%E7%9A%84%E6%9D%BF%E4%B8%AD%E6%9C%89%2032MB%20%E5%A4%A7%E5%B0%8F%E7%9A%84%20QSPI%20%E9%97%AA%E5%AD%98%E3%80%82up%20boot%20%E5%9C%A8%20QSPI%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E6%88%90%E5%8A%9F%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3E1.%E5%A6%82%E4%BD%95%E5%9C%A8%20i.MX8MPLUS%20%E4%B8%AD%E5%B0%86%E5%86%85%E6%A0%B8%E5%92%8C%20rootfs%20%E8%BD%BD%E5%85%A5%20QSPI%20%E9%97%AA%E5%AD%98%E3%80%82%3C%2FP%3E%3CP%3E2%E3%80%82%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%20i.MX8MPlus%20%E8%87%AA%E5%AE%9A%E4%B9%89%E4%B8%BB%E6%9D%BF%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E4%B8%8D%E6%94%AF%E6%8C%81%20eMMC%E3%80%81SD%E3%80%81%E4%B8%8E%E9%9D%9E%20%E5%92%8C%20USB%20%E7%AD%89%E8%AE%BE%E5%A4%87%E3%80%82%E6%B2%A1%E6%9C%89%E8%BF%99%E4%BA%9B%EF%BC%8C%E6%88%91%E4%BB%AC%E5%A6%82%E4%BD%95%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E5%92%8C%20rootfs%EF%BC%9F%3C%2FP%3E%3CP%3E3.%E6%98%AF%E5%90%A6%E6%9C%89%E4%B8%8D%E4%BD%BF%E7%94%A8%20SD%20%E5%8D%A1%E5%92%8C%20eMMC%20%E8%80%8C%E5%B0%86%E5%86%85%E6%A0%B8%E5%92%8C%20rootfs%20%E8%BD%BD%E5%85%A5%20QSPI%20%E9%97%AA%E5%AD%98%E7%9A%84%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20load%20kernel%20and%20rootfs%20into%20QSPI%20Flash%20in%20I.MX8MPLUS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234717%22%20target%3D%22_blank%22%3E%40Keta_S_Nitsure%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E7%9C%9F%E7%9A%84%E3%80%82%E6%88%91%E7%9C%9F%E7%9A%84%E4%B8%8D%E6%98%8E%E7%99%BD%E6%88%91%E7%9A%84%E5%9B%9E%E7%AD%94%E6%9C%89%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E3%80%82%E5%9C%A8%E6%88%91%E7%9A%84%E5%9B%9E%E5%A4%8D%E8%A2%AB%E5%88%A0%E9%99%A4%E5%90%8E%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%E5%8F%91%E5%B8%83%E4%BA%86%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E7%9B%B8%E4%BC%BC%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E4%BB%8E%E6%8A%80%E6%9C%AF%E4%B8%8A%E8%AE%B2%E4%B9%9F%E6%98%AF%E4%B8%80%E6%A0%B7%E7%9A%84%E3%80%82%E6%88%91%E8%BF%98%E6%98%AF%E4%B8%8D%E6%98%8E%E7%99%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E8%A6%81%E8%BF%99%E4%B9%88%E5%81%9A%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20load%20kernel%20and%20rootfs%20into%20QSPI%20Flash%20in%20I.MX8MPLUS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255591%22%20target%3D%22_blank%22%3E%40Sunil_13%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%EF%BC%8C%E4%B9%9F%E8%AE%B8%E4%BC%9A%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%E7%BB%99%E4%BD%A0%E7%9A%84%3CSTRONG%3E%E7%A7%81%E4%BA%BA%E4%BF%A1%E6%81%AF%3C%2FSTRONG%3E%E4%B8%AD%E6%8F%90%E5%88%B0%E4%BA%86%E8%BF%99%E4%BB%B6%E4%BA%8B%E3%80%82%20%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fall-bootloader-device-tree-Linux-kernel-rootfs-in-spi-nor-demo%2Fta-p%2F1663994%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fall-bootloader-device-tree-Linux-kernel-rootfs-in-spi-nor-demo%2Fta-p%2F1663994%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20load%20kernel%20and%20rootfs%20into%20QSPI%20Flash%20in%20I.MX8MPLUS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E5%88%A0%E9%99%A4%E4%BA%86%E6%88%91%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%9B%9E%E5%A4%8D%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E5%86%8D%E5%8F%91%E7%94%9F%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%8C%E6%88%91%E4%BF%9D%E8%AF%81%E4%BC%9A%E5%9C%A8%20Twitter%20%E4%B8%8A%E5%8F%91%E5%B8%83%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20load%20kernel%20and%20rootfs%20into%20QSPI%20Flash%20in%20I.MX8MPLUS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E7%A1%AE%E8%AE%A4%E8%BF%99%E6%98%AF%20X%20%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E5%B8%90%E6%88%B7%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222025-12-04_220155.png%22%20style%3D%22width%3A%20762px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222025-12-04_220155.png%22%20style%3D%22width%3A%20762px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222025-12-04_220155.png%22%20style%3D%22width%3A%20762px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222025-12-04_220155.png%22%20style%3D%22width%3A%20762px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368642i2FC1C039CC6474B5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222025-12-04_220155.png%22%20alt%3D%222025-12-04_220155.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20load%20kernel%20and%20rootfs%20into%20QSPI%20Flash%20in%20I.MX8MPLUS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%23%20%E5%A6%82%E4%BD%95%E5%9C%A8%20i.MX8MPlus%20%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E4%B8%8A%E5%B0%86%E5%86%85%E6%A0%B8%E5%92%8C%20rootFS%20%E5%8A%A0%E8%BD%BD%E5%88%B0%20QSPI%20%E9%97%AA%E5%AD%98%E4%B8%AD%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%BD%BF%E7%94%A8%2032MB%20QSPI%20%E9%97%AA%E5%AD%98%E4%B8%94%E6%B2%A1%E6%9C%89%20eMMC%E3%80%81SD%E3%80%81%E4%B8%8E%E9%9D%9E%E6%88%96%20USB%20%E8%AE%BE%E5%A4%87%EF%BC%8C%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%8E%A8%E8%8D%90%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%23%23%20QSPI%20Flash%20Boot%20Solution%3CBR%20%2F%3E%3CBR%20%2F%3EWhile%20your%20U-Boot%20has%20successfully%20booted%20from%20QSPI%2C%20there%20are%20important%20limitations%20to%20consider%3A%3CBR%20%2F%3E%3CBR%20%2F%3E1.%20The%2032MB%20QSPI%20flash%20is%20typically%20not%20large%20enough%20to%20hold%20a%20complete%20Linux%20rootFS.%20QSPI%20flash%20on%20i.MX8M%20Plus%20is%20primarily%20designed%20for%20storing%20U-Boot%2Fbootloader%20components.%3CBR%20%2F%3E%3CBR%20%2F%3E2.%20A%20practical%20approach%20is%20to%20implement%20a%20hybrid%20solution%3A%3CBR%20%2F%3E-%20Store%20U-Boot%20in%20QSPI%20flash%20(already%20accomplished)%3CBR%20%2F%3E-%20Store%20the%20kernel%20and%20device%20tree%20blob%20(DTB)%20in%20QSPI%20flash%3CBR%20%2F%3E-%20Implement%20a%20minimal%20initramfs%20for%20basic%20functionality%3CBR%20%2F%3E%3CBR%20%2F%3E%23%23%20%E5%AE%9E%E6%96%BD%E6%AD%A5%E9%AA%A4%3CBR%20%2F%3E%3CBR%20%2F%3E1.%20%E4%BD%BF%E7%94%A8%20imx-mkimage%20%E5%B7%A5%E5%85%B7%E7%94%9F%E6%88%90%20QSPI%20%E5%8F%AF%E5%90%AF%E5%8A%A8%E6%98%A0%E5%83%8F%EF%BC%9A%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3Emake%20SOC%3DiMX8MP%20flash_evk_flexspi%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3E2.%20%E5%9C%A8%20QSPI%20%E9%97%AA%E5%AD%98%E4%B8%AD%E5%88%9B%E5%BB%BA%E5%A4%A7%E5%B0%8F%E8%BF%91%E4%BC%BC%E7%9A%84%E5%88%86%E5%8C%BA%EF%BC%9A%3CBR%20%2F%3E-%20U-Boot%EF%BC%9A512KB%EF%BC%88%E5%B7%B2%E5%88%B7%E6%96%B0%EF%BC%89%3CBR%20%2F%3E-%20Linux%20%E5%86%85%E6%A0%B8%EF%BC%9A%E7%BA%A6%209MB%3CBR%20%2F%3E-%20%E8%AE%BE%E5%A4%87%E6%A0%91%20blob%EF%BC%9A%E7%BA%A6%2064KB%3CBR%20%2F%3E-%20U-Boot%20%E7%8E%AF%E5%A2%83%EF%BC%9A%E7%BA%A6%2064KB%3CBR%20%2F%3E-%20initramFS%EF%BC%88%E6%9C%80%E5%B0%8F%20rootFS%EF%BC%89%EF%BC%9A%E7%BA%A6%2022MB%3CBR%20%2F%3E%3CBR%20%2F%3E3.%20%E5%B0%86%20U-Boot%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%BB%8E%20QSPI%20%E9%97%AA%E5%AD%98%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E5%92%8C%20DTB%EF%BC%9A%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3Esf%20probe%3CBR%20%2F%3Esf%20read%20%24%7Bloadaddr%7D%200x80000%200x900000%20%23%20%E4%BB%8E%20QSPI%20%E8%AF%BB%E5%8F%96%E5%86%85%E6%A0%B8%3CBR%20%2F%3Esf%20read%20%24%7Bfdt_addr%7D%200x980000%200x10000%20%23%20%E4%BB%8E%20QSPI%20%E8%AF%BB%E5%8F%96%20DTB%3CBR%20%2F%3E%60%60%60%3CBR%20%2F%3E%3CBR%20%2F%3E4.%20%E4%BD%BF%E7%94%A8%E9%80%82%E5%90%88%E5%8F%AF%E7%94%A8%E7%A9%BA%E9%97%B4%E7%9A%84%E5%9F%BA%E6%9C%AC%E5%B7%A5%E5%85%B7%E5%92%8C%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%88%9B%E5%BB%BA%E6%9C%80%E5%B0%8F%E7%9A%84%20initramfs%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E5.%E5%AF%B9%E4%BA%8E%E6%9B%B4%E5%A4%8D%E6%9D%82%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E8%80%83%E8%99%91%E4%B8%BA%E5%AE%8C%E6%95%B4%E7%9A%84%20rootFS%20%E5%AE%9E%E7%8E%B0%E7%BD%91%E7%BB%9C%E5%90%AF%E5%8A%A8%E6%94%AF%E6%8C%81%20(NFS)%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E7%A7%8D%E6%96%B9%E6%B3%95%E4%B8%BA%E5%9C%A8%E7%8E%B0%E6%9C%89%E7%A1%AC%E4%BB%B6%E9%99%90%E5%88%B6%E4%B8%8B%E5%90%AF%E5%8A%A8%E7%B3%BB%E7%BB%9F%E6%8F%90%E4%BE%9B%E4%BA%86%E5%8F%AF%E8%A1%8C%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20load%20kernel%20and%20rootfs%20into%20QSPI%20Flash%20in%20I.MX8MPLUS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254926%22%20target%3D%22_blank%22%3E%40Adele%3C%2FA%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E8%AF%B4%E7%9A%84%E6%98%AF%E7%9C%9F%E7%9A%84%EF%BC%8C%E9%82%A3%E7%9C%9F%E6%98%AF%E9%9A%BE%E4%BB%A5%E7%BD%AE%E4%BF%A1%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
