Hi Sanket Parekh,
I've tried to use kernel 6.1. but failed. It stops at starting. Please see appended log.
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.36 (bheinz@bernd-tower) (aarch64-linux-gnu-gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #9 SMP PREEMPT Wed Nov 22 11:48:12 CET 2023
[ 0.000000] Machine model: DESKO PENTA4X Gen1
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000007f600000, size 10 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x7f3be700-0x7f3c0fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000055ffffff]
[ 0.000000] node 0: [mem 0x0000000058000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] On node 0, zone DMA: 8192 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 20 pages/cpu s44520 r8192 d29208 u81920
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 249856
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttymxc1,115200 root=/dev/nfs rw ip=dhcp nfsroot=192.168.101.94:/home/desko/penta4x/rootfs,v3,tcp
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 952964K/1015808K available (19392K kernel code, 1618K rwdata, 6804K rodata, 3328K init, 645K bss, 52604K reserved, 10240K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 160 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000000] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000454] Console: colour dummy device 80x25
[ 0.000518] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.000528] pid_max: default: 32768 minimum: 301
[ 0.000588] LSM: Security Framework initializing
[ 0.000671] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.000681] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.002007] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002019] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002084] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002238] rcu: Hierarchical SRCU implementation.
[ 0.002241] rcu: Max phase no-delay instances is 1000.
[ 0.003721] EFI services will not be available.
[ 0.003971] smp: Bringing up secondary CPUs ...
[ 0.004397] Detected VIPT I-cache on CPU1
[ 0.004475] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.004514] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.004989] Detected VIPT I-cache on CPU2
[ 0.005048] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.005068] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.005475] Detected VIPT I-cache on CPU3
[ 0.005530] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.005548] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.005599] smp: Brought up 1 node, 4 CPUs
[ 0.005605] SMP: Total of 4 processors activated.
[ 0.005609] CPU features: detected: 32-bit EL0 Support
[ 0.005612] CPU features: detected: 32-bit EL1 Support
[ 0.005616] CPU features: detected: CRC32 instructions
[ 0.005672] CPU: All CPU(s) started at EL2
[ 0.005695] alternatives: applying system-wide alternatives
[ 0.007195] devtmpfs: initialized
[ 0.015251] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.015275] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.015736] pinctrl core: initialized pinctrl subsystem
[ 0.018283] DMI not present or invalid.
[ 0.018902] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.020379] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.020965] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.021407] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.021484] audit: initializing netlink subsys (disabled)
[ 0.021686] audit: type=2000 audit(0.016:1): state=initialized audit_enabled=0 res=1
[ 0.022231] thermal_sys: Registered thermal governor 'step_wise'
[ 0.022235] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.022275] cpuidle: using governor menu
[ 0.022576] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.022657] ASID allocator initialised with 65536 entries
[ 0.023709] Serial: AMBA PL011 UART driver
[ 0.023767] imx mu driver is registered.
[ 0.023787] imx rpmsg driver is registered.
[ 0.033631] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.042236] platform 32e00000.isi: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a40000/ar1820@37
[ 0.042612] platform 32e40000.csi: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a40000/ar1820@37
[ 0.051261] KASLR disabled due to lack of seed
[ 0.069905] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.069917] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.069922] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.069927] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.069932] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.069935] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.069939] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.069942] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.071865] ACPI: Interpreter disabled.
[ 0.072572] iommu: Default domain type: Translated
[ 0.072577] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.072845] SCSI subsystem initialized
[ 0.073150] usbcore: registered new interface driver usbfs
[ 0.073190] usbcore: registered new interface driver hub
[ 0.073215] usbcore: registered new device driver usb
[ 0.074554] mc: Linux media interface: v0.10
[ 0.074588] videodev: Linux video capture interface: v2.00
[ 0.074658] pps_core: LinuxPPS API ver. 1 registered
[ 0.074662] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.074678] PTP clock support registered
[ 0.074842] EDAC MC: Ver: 3.0.0
[ 0.075961] FPGA manager framework
[ 0.076034] Advanced Linux Sound Architecture Driver Initialized.
[ 0.076577] Bluetooth: Core ver 2.22
[ 0.076605] NET: Registered PF_BLUETOOTH protocol family
[ 0.076609] Bluetooth: HCI device and connection manager initialized
[ 0.076616] Bluetooth: HCI socket layer initialized
[ 0.076622] Bluetooth: L2CAP socket layer initialized
[ 0.076633] Bluetooth: SCO socket layer initialized
[ 0.076989] vgaarb: loaded
[ 0.077581] clocksource: Switched to clocksource arch_sys_counter
[ 0.077775] VFS: Disk quotas dquot_6.6.0
[ 0.077815] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.077983] pnp: PnP ACPI: disabled
[ 0.084747] NET: Registered PF_INET protocol family
[ 0.084884] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.085824] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.085845] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.085858] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.085917] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.086135] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.086214] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.086241] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.086354] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.086662] RPC: Registered named UNIX socket transport module.
[ 0.086667] RPC: Registered udp transport module.
[ 0.086670] RPC: Registered tcp transport module.
[ 0.086673] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.087443] PCI: CLS 0 bytes, default 64
[ 0.088286] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.089187] kvm [1]: IPA Size Limit: 40 bits
[ 0.090742] kvm [1]: GICv3: no GICV resource entry
[ 0.090748] kvm [1]: disabling GICv2 emulation
[ 0.090760] kvm [1]: GIC system register CPU interface enabled
[ 0.090844] kvm [1]: vgic interrupt IRQ9
[ 0.090924] kvm [1]: Hyp mode initialized successfully
[ 0.092080] Initialise system trusted keyrings
[ 0.092260] workingset: timestamp_bits=42 max_order=18 bucket_order=0
[ 0.098562] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.099153] NFS: Registering the id_resolver key type
[ 0.099188] Key type id_resolver registered
[ 0.099192] Key type id_legacy registered
[ 0.099258] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.099263] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.099284] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.099604] 9p: Installing v9fs 9p2000 file system support
[ 0.135225] Key type asymmetric registered
[ 0.135230] Asymmetric key parser 'x509' registered
[ 0.135277] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.135283] io scheduler mq-deadline registered
[ 0.135287] io scheduler kyber registered
[ 0.143058] EINJ: ACPI disabled.
[ 0.154739] imx-sdma 30bd0000.dma-controller: firmware found.
[ 0.154894] imx-sdma 30bd0000.dma-controller: loaded firmware 4.5
[ 0.157036] mxs-dma 33000000.dma-apbh: initialized
[ 0.158850] SoC: i.MX8MP revision 1.1
[ 0.159886] Bus freq driver module loaded
[ 0.166858] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.169376] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 17, base_baud = 5000000) is a IMX
[ 0.169987] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 18, base_baud = 5000000) is a IMX
[ 0.170453] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 19, base_baud = 1500000) is a IMX
[ 1.272609] printk: console [ttymxc1] enabled
[ 1.278827] imx-drm display-subsystem: no available port
[ 1.296485] loop: module loaded
[ 1.301030] of_reserved_mem_lookup() returned NULL
[ 1.305993] megasas: 07.719.03.00-rc1
[ 1.315071] spi-nor spi0.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00
[ 1.324869] tun: Universal TUN/TAP device driver, 1.6
[ 1.330969] thunder_xcv, ver 1.0
[ 1.334246] thunder_bgx, ver 1.0
[ 1.337504] nicpf, ver 1.0
[ 1.342529] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 1.349772] hns3: Copyright (c) 2017 Huawei Corporation.
[ 1.355140] hclge is initializing
[ 1.358478] e1000: Intel(R) PRO/1000 Network Driver
[ 1.363361] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 1.369158] e1000e: Intel(R) PRO/1000 Network Driver
[ 1.374128] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.380089] igb: Intel(R) Gigabit Ethernet Network Driver
[ 1.385533] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.391142] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 1.397415] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.403544] sky2: driver version 1.30
[ 1.407866] usbcore: registered new interface driver r8152
[ 1.413656] VFIO - User Level meta-driver version: 0.3
[ 1.420146] imx8mp-dwc3 32f10100.usb: Base address for glue layer missing. Continuing without, some features are missing though.
[ 1.433156] imx8mp-dwc3 32f10108.usb: Base address for glue layer missing. Continuing without, some features are missing though.
[ 1.448884] usbcore: registered new interface driver uas
[ 1.454288] usbcore: registered new interface driver usb-storage
[ 1.460367] usbcore: registered new interface driver usbserial_generic
[ 1.466921] usbserial: USB Serial support registered for generic
[ 1.472956] usbcore: registered new interface driver ftdi_sio
[ 1.478723] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.486083] usbcore: registered new interface driver usb_serial_simple
[ 1.492633] usbserial: USB Serial support registered for carelink
[ 1.498746] usbserial: USB Serial support registered for zio
[ 1.504427] usbserial: USB Serial support registered for funsoft
[ 1.510457] usbserial: USB Serial support registered for flashloader
[ 1.516836] usbserial: USB Serial support registered for google
[ 1.522776] usbserial: USB Serial support registered for libtransistor
[ 1.529322] usbserial: USB Serial support registered for vivopay
[ 1.535351] usbserial: USB Serial support registered for moto_modem
[ 1.541640] usbserial: USB Serial support registered for motorola_tetra
[ 1.548274] usbserial: USB Serial support registered for nokia
[ 1.554138] usbserial: USB Serial support registered for novatel_gps
[ 1.560516] usbserial: USB Serial support registered for hp4x
[ 1.566283] usbserial: USB Serial support registered for suunto
[ 1.572224] usbserial: USB Serial support registered for siemens_mpi
[ 1.578613] usbcore: registered new interface driver usb_ehset_test
[ 1.588032] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 1.602775] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
[ 1.608995] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01T00:00:00 UTC (0)
[ 1.618188] i2c_dev: i2c /dev entries driver
[ 1.627730] Bluetooth: HCI UART driver ver 2.3
[ 1.632206] Bluetooth: HCI UART protocol H4 registered
[ 1.637352] Bluetooth: HCI UART protocol BCSP registered
[ 1.642690] Bluetooth: HCI UART protocol LL registered
[ 1.647837] Bluetooth: HCI UART protocol ATH3K registered
[ 1.653258] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 1.659625] Bluetooth: HCI UART protocol Broadcom registered
[ 1.665316] Bluetooth: HCI UART protocol QCA registered
[ 1.672138] sdhci: Secure Digital Host Controller Interface driver
[ 1.678357] sdhci: Copyright(c) Pierre Ossman
[ 1.683521] Synopsys Designware Multimedia Card Interface Driver
[ 1.690273] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.698790] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.706024] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.712989] usbcore: registered new interface driver usbhid
[ 1.718573] usbhid: USB HID core driver
[ 1.727666] cs_system_cfg: CoreSight Configuration manager initialised
[ 1.730527] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 1.736000] optee: probing for conduit method.
[ 1.745910] optee: revision 3.13 (2c1092df)
[ 1.746917] optee: dynamic shared memory is enabled
[ 1.756359] optee: initialized driver
[ 1.763148] Galcore version 6.4.11.p2.684571
[ 1.793367] [drm] Initialized vivante 1.0.0 20170808 for 40000000.mix_gpu_ml on minor 0
[ 1.803314] hantrodec 0 : module inserted. Major = 510
[ 1.808995] hantrodec 1 : module inserted. Major = 510
[ 1.815741] hantroenc: HW at base <0000000038320000> with ID <0x80006200>
[ 1.822700] hx280enc: module inserted. Major <509>
[ 1.830567] NET: Registered PF_LLC protocol family
[ 1.836705] NET: Registered PF_INET6 protocol family
[ 1.843700] Segment Routing with IPv6
[ 1.847434] In-situ OAM (IOAM) with IPv6
[ 1.851427] NET: Registered PF_PACKET protocol family
[ 1.851984] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[ 1.856522] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.864010] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB
[ 1.876805] Bluetooth: RFCOMM TTY layer initialized
[ 1.885263] Bluetooth: RFCOMM socket layer initialized
[ 1.885524] mmcblk2: p1 p2 p3 p4 p5 p6
[ 1.890431] Bluetooth: RFCOMM ver 1.11
[ 1.898024] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.898987] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB
[ 1.903345] Bluetooth: BNEP filters: protocol multicast
[ 1.903357] Bluetooth: BNEP socket layer initialized
[ 1.903362] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.909611] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB
[ 1.913567] Bluetooth: HIDP socket layer initialized
[ 1.919650] mmcblk2rpmb: mmc2:0001 8GTF4R 512 KiB, chardev (234:0)
[ 1.925485] 8021q: 802.1Q VLAN Support v1.8
[ 1.944813] lib80211: common routines for IEEE802.11 drivers
[ 1.950626] 9pnet: Installing 9P2000 support
[ 1.955054] Key type dns_resolver registered
[ 1.960388] registered taskstats version 1
[ 1.964517] Loading compiled-in X.509 certificates
[ 2.059744] nxp-pca9450 0-0025: pca9450bc probed.
[ 2.064583] i2c i2c-0: IMX I2C adapter registered
[ 2.071208] i2c i2c-2: IMX I2C adapter registered
[ 2.076671] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
[ 2.085308] imx8mq-usb-phy 382f0040.usb-phy: supply vbus not found, using dummy regulator
[ 2.093806] imx8-pcie-phy 32f00000.pcie-phy: failed to get imx pcie phy clock
[ 2.100989] imx8-pcie-phy: probe of 32f00000.pcie-phy failed with error -2
No further output after several minutes.
Bernd
