How to install gpiod on prebuilt nxp images for imx8mm
808 次查看
Mostafa_Ronia
I'm currently utilizing the evaluation board image (imx-image-full-imx8mmevk.wic) for imx8mm. However, I've noticed that gpiod is not installed, and attempts to install it via apt-get have been unsuccessful. Could someone kindly provide guidance on resolving this issue or installing gpiod? Perhaps updating my apt-get repositories could be a solution?
Thank you.
791 次查看
Chavira
Hi @Mostafa_Ronia!
Thank you for contacting NXP Support!
To add any package based on our BSP you have to compile the image.
You have to add the next on the conf/local.conf .
Examples:
IMAGE_INSTALL += "pcsc-lite"
IMAGE_INSTALL += "pcsc-lite-dev"
IMAGE_INSTALL += "pcsc-lite-lib"
And then compile the image using the command bitbake <image>
The image could be "imx-image-multimedia",
"imx-image-full",
"imx-image-core", etc.
https://www.nxp.com/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
Best Regards!
Chavira
792 次查看
Chavira
Hi @Mostafa_Ronia!
Examples:
"imx-image-full",
Best Regards!
Chavira
