How to install PortAudio package on iMX6UL ?
4,450件の閲覧回数
toanjunifer
Senior Contributor I
Hi NXPs,
My name is Toan. And I trying to install pyaudio on python3.  When use:
$ pip3 install pyaudio
I recognize that it's require PortAudio package. Then I try add "portaudio-v19" on local.conf and execute bitbake command without error. But when I try install pyaudio again. It's still show the same error.
So how can I do now ?
Thank you so much,
Toan
4,290件の閲覧回数
karangajjar
Senior Contributor II
Hi Dao Van Toan,
You can download the https://files.pythonhosted.org/packages/ab/42/b4f04721c5c5bfc196ce156b3c768998ef8c0ae3654ed29ea5020c...  PyAudio-0.2.11.tar.gz file from the above link. Follow the INSTALL instruction. After successful installation you can use import pyaudio inside your python file.
Let us know in case of any concern.
Karan Gajjar
3 返答(返信)
4,291件の閲覧回数
karangajjar
Hi Dao Van Toan,
Karan Gajjar
3,773件の閲覧回数
unscripted1
I' m having similar issues.
What I am trying to do is install PortAudio Library on my nxp board
import sounddevice as sd
File "/usr/lib/python3.9/site-packages/sounddevice.py", line 71, in <module>
raise OSError('PortAudio library not found')
OSError: PortAudio library not found
Can i get installation guide?
I am working on IMX8 PLUS
4,290件の閲覧回数
toanjunifer
Hi karan.gajjar@volansystech.com‌,
Thank you very much for your support. I'm going to try follow your guide.
Toan
