How to implement device tree file to support SD/MMC (SDIO interface)on Imx8mm
billwu
Dear Sir,
We want to bring up Wifi module by using SD/MMC (SDIO interface) and the name of interface is mmc1.
I have tried to implement "imx8mm-evk.dts" but it seem is not work.
Attached file is modified file.(imx8mm-evk.dts).
Is my understanding correct for imx8mm-evk.dts?
Would you mind checking it,thank you.
Below is our target setting.
B.R.
Bill
joanxie
billwu
Dear Joanxie,
Thank for your information.
I have a question about the uSDHC1.  Is the uSDHC1 the same Micro-SD(SD2)(ref:below picture).
Sorry for the confusion, I said mmc1 means to Micro-SD.
B.R.
Bill
joanxie
pls see his :
SDHC2 is for MicroSD , SDHC1 is for IWFI/BT
billwu
Dear Joanxie
If I want to use SDIO interface of SDHC2, could I reference "https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Enabling-uSDHC1-of-i-MX8MM-Based-On-L5-4..."?
B.R.
Bill
joanxie
yes, this document is for uSDHC1, if you need to use uSDHC2, you can refer to the document and change the dts according to your own design
joanxie
