How to implement android Hardware HOME_KEY Function
3,202 次查看
lifusong
Dear sir.
   AS the title,any body can help me?
any reply is helpful.
BSP version is 4.4.3_r1 kernel 3.10.53 uboot 2014.04
there HAVE a GPIO Pin can used by detect HOME_KEY press
标签 (2)
2,988 次查看
lifusong
Only Need Add code inside dts file ,look seem as voluem and the different is the linux_code
4 回复数
2,988 次查看
lifusong
help please.
2,988 次查看
CarlosCasillas
On the following links you could find useful information that may help you to implement the HOME_KEY functionality on Android:
Android Buttons - IOMUX - safeMode
http://stackoverflow.com/questions/2208912/how-can-i-detect-user-pressing-home-key-in-my-activity
https://groups.google.com/forum/#!topic/android-porting/Gd90_zQNZEM
Hope this will be useful for you.
Best regards!
/Carlos
2,988 次查看
lifusong
Hi CarlosCasillas
thanks for your reply.
we use bsp version is 4.4.3_r1 and kernel is 3.10.53 ,so this function defined in the dts file.but  from FSL office web download the source code don't have HOME_KEY defined. i don't know how to do it.
HOME_KEY function inside android os depend android APP to implement  it or android os have this function?
below link is my asked at google groups.
2,989 次查看
lifusong
