I have an im8mq evk board.
Is it possible to get the runtime clock of GPU ?
I can't find any info about this from document
 Bio_TICFSL
			Bio_TICFSL
		Hello Liou,
Available clock options can be found in driver sources:
linux/drivers/clk/imx/clk-imx8mq.c
clk-imx8mq.c\imx\clk\drivers - linux-imx - i.MX Linux kernel
dts file
fsl-imx8mq.dtsi\freescale\dts\boot\arm64\arch - linux-imx - i.MX Linux kernel
Linux common clock framework documentation
clk.txt\Documentation - linux-imx - i.MX Linux kernel
https://elinux.org/images/b/b8/Elc2013_Clement.pdf
Linux 4.9.88_2.0.0 BSP & Multimedia Codecs Documentation
Hi Bio,
I think the info you provided is the setting clock, not the runtime clock.
The thermal will influences the gpu clock for reducing device temperature.
How can I get the 'runtime' gpu clock ?
Hi NXP,
Can help this question ?
