How to generate XML for any sensor to use integrated ISP on IMX8M Plus?
2,702 次查看
darsh_dev
I went through multiple thread/discussion to use ISP of IMX8M Plus for sensor other than Basler. From ISP working in i.MX8M Plus - NXP Community I am able to find out .drv, .xml files are required apart from kernel driver. After referring mentioned thread I know how to generate .drv but still there is no information on how to get .xml files for respective sensor. Is there any tool to generate XML for respective sensor?
Wanted to know what kind of support NXP can provide to use ISP on IMX8M Plus for sensor other than basler.
Darshak
标记 (2)
2,680 次查看
Bio_TICFSL
Hello darshak,
In this case the vendor should provide you the driver and the xml if it the case.
2,661 次查看
darsh_dev
Thanks @Bio_TICFSL
Definitely, we will collect the camera driver from the vendor, I'm afraid about the tuning/Calibration XML file (i.e. OV2775_8M_02_1080p.xml available with ISP-IMX )
I will also check with the vendor. What I thought is, using some tuning/calibration tool, it should be generated.
