How to erase boot1 partition
zhongyue_li
Dear NXP Engineer,
This is Li Zhongyue who is working on imx android solution.
I would like to know how to re-write boot1 partition.
Following is my operations, could you help to check if they are correct or not?
1. Erase the block data in boot1 partition first, (API: blk_derase(...))
2. Then write the new data to the same block, (API: blk_dwrite(...))
3. Read the same block, the data is still the old one. (API: blk_dread(...))
And, there are no any errors when i was doing erasing and writing operations.
Or could you give me a guide how to re-write boot1 partition correctly?
Thanks a million.
Have a nice day.
zhongyue_li
Dear igorpadykov,
As far as i know, if i want to write new data to the block which has been written previously,
i need to erase the block firstly.
This is NAND storage basic principle, am i right?
And i would like to know how to erase boot1 partition, is it possible to erase boot1 partition?
Is there any limitation to erase boot1 partition?
Thanks a million.
Have a nice day.
for handling boot partitions one can look on
Mfgtools  emmc boot issue fix
zhongyue_li
Dear igorpadykov,
Thank you so much for your quick response.
I checked the links you shared, however, i didnot find the way to erase or re-write boot1 partition.
there are only the way that how to download bootloader to boot0 partition,
could you give me suggestion to erase boot1 partition?
And one more question, do you know how to modify the boot1 partition size, RPMB partition size?
Thanks a lot.
Best regards!.
Hi Li
what do you mean by "way to erase or re-write boot1 partition" .
According to emmc specification boot area partitions dimensions and technology features
are defined by the memory manufacturer.
Hi Li
one can look at android documentation on below link
i.MX Software | NXP
or uuu sample scripts included in Demo Images on that link or
Sample script · NXPmicro/mfgtools Wiki · GitHub
https://boundarydevices.com/programming-emmc-on-i-mx6/
