How to enable dm-verity in linux 6.x
3,622 次查看
Aravinthkumar
Hi Team,
I'm using Linux bsp kernel 6.1 version on imx6dl sabresd. Can you please help me how to enable and use dm-verity.
Aravinth
3,599 次查看
Sanket_Parekh
I hope you are doing well.
Please find the configuration for the device-mapper below.
Device Drivers --> RAID and LVM Support --> you should find "device mapper support"
For more information related to the device mapper, kindly refer to the below documents.
1) One can refer to section 3.4 Configurations in Linux/Android platform for security features in i.MX_Android_Security_User's_Guide.pdf
Thanks & Regards,
Sanket Parekh
3,592 次查看
Aravinthkumar
Hi @Sanket_Parekh,
Thanks for immediate response.
1)i.MX_Android_Security_User's_Guide.pdf --> this pdf has more details about Android not much on linux
2) App-note:- AN12714 i.MX Encrypted Storage Using CAAM Secure Keys --> As mentioned earlier we are not using dm-crypt, we are using only dm-verity.
3) https://elinux.org/images/e/e0/Josserand-schulz-secure-boot.pdf - It's generic document about secure boot.
Can you please help exactly how to setup and use dm-verity on imx6dl sabresd linux platform.
Aravinth
3,545 次查看
Sanket_Parekh
These are the available documents from NXP for this feature.
As it is supported by the Yocto layer, you can post this issue in the yocto community.
Reference link: https://lists.yoctoproject.org/g/yocto/message/49112
My apology for the inconvenience.
Thanks & Regards
Sanket Parekh
