How to enable USB debugging support for sabre-sd?
4,026 次查看
niharika
I am using iMX6 Sabre-sd board. I am able to boot up the board but I am not able to see the USB debugging option in settings.
Android version 4.2.2.
Model number: SABRESD-MX6DQ
标签 (2)
3,562 次查看
rickchu
click "Build number" several times quickly, then developer options will be turn on.
4 回复数
3,562 次查看
niharika
Thanks Rick Chu for your help..
3,562 次查看
rickchu
3,562 次查看
ZeeFrench
Please check the FAQ in the document package (document tab, for latest JB: https://www.freescale.com/webapp/Download?colCode=IMX6_JB422_110_ANDROID_DOCS&location=null&fpsp=1&P...) , USB debugging is part of developper settings menu :
27 How do I enable developer settings on Android 4.2?
Google has hidden the developer settings in the latest version of Jelly Bean. The following steps explain how to retrieve developer settings:
• Go to the settings menu and scroll down to "About phone." Tap it.
• Scroll down to the bottom again until you see "Build number."
• Tap it seven (7) times. After the third tap, you'll see a playful dialog that says you're four taps away from being a
developer.
• Keep on tapping, until you've got the developer settings back.
Cheers, Philippe.
3,562 次查看
niharika
Hello Philippe,
Thanks for your reply. I am able to figured this out.
Thanks for your help.
Niharika.
