How to dump camera data on i.MX8
xu_ji1
Contributor V
hello,
How to dump camera raw data  that not pass through ISI to verify pure camera data correct or not on i.MX8?
joanxie
do you need to check the raw data from camera? if yes, you should dump the memory which store the camera data
xu_ji1
Contributor V
It is yes,I try to dump memory after V4L2 dequeue operation,does it the pure camera data not pass through i.MX8 ISI?
joanxie
you can send the camera data to memory, then read the raw data from memory,don't dump memory after v4l2
