For the latest DDR stress test tool version and notes, please look here:
https://community.nxp.com/docs/DOC-105652
To make the tool run correctly on a custom hardware, you first have to generate the appropriate initialization script using the appropriate DDR Register Programming Aid sheet that can be taken from here:
https://community.nxp.com/docs/DOC-236354
Then, you have to run the tool, load the initialization script and then perform the tests. The ZQ calibration is performed automatically by the tool.
Artur
