How to display video capture by OS08A20 camera via HDMI(LT8912)?
4,170件の閲覧回数
kazuhito_morita
Could you please tell me how to display video captured by the OS08A20 camera via HDMI(LT8912)?
■ Environment
GST_DEBUG=3 gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,width=1920,height=1080,format=YUYV" ! videoconvert ! autovideosink
■ Result
0:00:00.083718541 916 0xaaaaf3247f20 ERROR GST_PIPELINE grammar.y:1138:gst_parse_perform_link: could not link v4l2src0 to videoconvert0, neither element can handle caps video/x-raw, width=(int)1920, height=(int)1080, format=(string)YUYV WARNING: erroneous pipeline: could not link v4l2src0 to videoconvert0, neither element can handle caps video/x-raw, width=(int)1920, height=(int)1080, format=(string)YUYV
If any additional information is needed, please let me know.
Thank you in advance!
ラベル(2)
タグ(3)
22 返答(返信)
3,789件の閲覧回数
Rita_Wang
I have tried  on the i.MX 95 EVK running 6.12.20_2.0.0 BSP, it can run well.
Run the example Gstreamer pipeline to verify camera stream
root@imx95evk:~# gst-launch-1.0 libcamerasrc ! queue ! autovideosink
3,750件の閲覧回数
kazuhito_morita
@Rita_Wang
Thank you for checking.
I tried the GStreamer pipeline you suggested, but I encountered an error.
I will investigate the details of the error.
[0:01:47.980555800] [624]  INFO Camera camera_manager.cpp:315 libcamera v0.0.0+4594-lf-6.6.23-2.0.0-dirty (2025-09-05T01:32:47+00:00)
[0:01:48.031624883] [629]  INFO NxpNeo neo_utils.cpp:629 Parsing pipeline config file /usr/share/libcamera/pipeline/nxp/neo/config.yaml
[0:01:48.033805175] [629]  WARN CameraSensor camera_sensor.cpp:248 'os08a20 2-0036': Recommended V4L2 control 0x009a0922 not supported
[0:01:48.033880508] [629]  WARN CameraSensor camera_sensor.cpp:315 'os08a20 2-0036': The sensor kernel driver needs to be fixed
[0:01:48.033911467] [629]  WARN CameraSensor camera_sensor.cpp:317 'os08a20 2-0036': See Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[0:01:48.034876550] [629]  WARN CameraSensorProperties camera_sensor_properties.cpp:262 No static properties available for 'os08a20'
[0:01:48.034923050] [629]  WARN CameraSensorProperties camera_sensor_properties.cpp:264 Please consider updating the camera sensor properties database
[0:01:48.034952592] [629]  WARN CameraSensor camera_sensor.cpp:461 'os08a20 2-0036': Failed to retrieve the camera location
[0:01:48.034980800] [629]  WARN CameraSensor camera_sensor.cpp:483 'os08a20 2-0036': Rotation control not available, default to 0 degrees
Pipeline is live and does not need PREROLL ...
ERROR: from element /GstPipeline:pipeline0/GstLibcameraSrc:libcamerasrc0: Internal data stream error.
Pipeline is PREROLLED ...
Additional debug info:
/usr/src/debug/libcamera/0.2.0.imx/src/gstreamer/gstlibcamerasrc.cpp(645): gst_libcamera_src_task_enter (): /GstPipeline:pipeline0/GstLibcameraSrc:libcamerasrc0:
streaming stopped, reason not-negotiated (-4)
Setting pipeline to PLAYING ...
ERROR: pipeline doesn't want to preroll.
I would appreciate it if you could advise me on anything else I should try or check.
3,748件の閲覧回数
Rita_Wang
Hi @kazuhito_morita ,
Can you share the board picture to me? I do not know the verison Board in your side, B0 or A1 version, thanks.
Wish you have a nice day
Best Regards
Rita
3,737件の閲覧回数
kazuhito_morita
Hi, @Rita_Wang
Thank you for your cheking.
I’m attaching a photo of the board.
Please take a look and let me know what you think.
best regards.
3,699件の閲覧回数
Rita_Wang
I see the board you are using, it is not our EVK board, here I will test the OS08A20 camera via HDMI on our EVK board and then tell you the result.
By the way, in China we will have the China National days leave from today and I will test i for you when I back to office on the Oct 9th. Thanks for kindly understandings.
Best Regards
Rita
3,648件の閲覧回数
kazuhito_morita
@Rita_Wang
Thank you very much for your support.
Wishing you a wonderful holiday!
3,302件の閲覧回数
Rita_Wang
Thank you, I am back and discussed with my colleague,you also need to run the following commend :
export LIBCAMERA_PIPELINES_MATCH_LIST='nxp/neo,imx8-isi,uvcvideo'
You can try it, I will wait for your test result.  If still not work tell me.
Best Regards
Rita
3,138件の閲覧回数
kazuhito_morita
@Rita_Wang
Thank you for your advice.
However, I still cannot display the camera image.
Here are the steps I executed:
GST_DEBUG=3 gst-launch-1.0 libcamerasrc ! queue ! autovideosink
RESULT
The following debug messages appear in the console:
[0:01:38.381866712] [780] INFO Camera camera_manager.cpp:326 libcamera v0.0.0+5937-lf-6.12.34-2.1.0
[0:01:38.507243420] [784] INFO NxpNeoIPA neo_ipa.cpp:131 nxpneo: IPANxpNeo NXPNEO_IPA_v0.0.0+5937-lf-6.12.34-2.1.0
0:00:00.611470375 780 0xffff84000b70 FIXME default gstutils.c:4169:gst_element_decorate_stream_id_internal:<libcamerasrc0> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:00.612225292 780 0xffff84000b70 WARN default gstlibcamera-utils.cpp:345:gst_libcamera_stream_formats_to_caps: Unsupported DRM format R10
New clock: GstSystemClock
0:00:00.612294792 780 0xffff84000b70 WARN default gstlibcamera-utils.cpp:345:gst_libcamera_stream_formats_to_caps: Unsupported DRM format R12
0:00:00.612571875 780 0xffff84000b70 WARN default gstlibcamera-utils.cpp:345:gst_libcamera_stream_formats_to_caps: Unsupported DRM format XVUY
[0:01:38.925148004] [785] INFO Camera camera.cpp:1205 configuring streams: (0) 3840x2160-NV21/sYCC
0:00:00.0 / 99:99:99.:99.
The counter remains at 0:00:00.0 and does not count up.
When I boot the NXP BSP, Weston seems to start automatically.
A gray background and some application icons are displayed — could this be affecting the camera display?
2,973件の閲覧回数
Rita_Wang
We do not have your board in hand, so can not debug it for, I confirmed in our side, for the in iMX95 Verdin board support you can contact the Toradex
Toradex - Customer Support
Hope this can do help for you
Best Regards
Rita
2,952件の閲覧回数
kazuhito_morita
hi, @Rita_Wang
Thank you very much for all your support so far.
You were able to output the input image from the OS08A20 camera via HDMI, and I would like to refer to your implementation.
Would it be possible for you to share the following information?
  • The version of NSP-BSP you are using
  • The console output of the media-ctl -p command executed on your board
  • The console output of the zcat /proc/config.gz command executed on your board
  • The DTS file you are using
2,021件の閲覧回数
Rita_Wang
Dtb file I use this one: fdtfile=imx95-19x19-evk-os08a20-isp-it6263-lvds0.dtb
For the
You need I add them to the attachment.
By the way,  if still not work in your side. You can use the support way I share you last time.
Best Regads
Rita
2,923件の閲覧回数
Rita_Wang
Good news it work now.
I will send you next week I go to office and then share it to you.
2,470件の閲覧回数
kazuhito_morita
Hi, @Rita_Wang
Could you please share the following information about your environment?
  • The version of the NSP-BSP you are using
2,075件の閲覧回数
Rita_Wang
I am using the newest version BSP in our website:
For the others
I will test on our board later and then give you reply, so sorry for late test on it, too many task in hand.
2,049件の閲覧回数
kazuhito_morita
Hi @Rita_Wang
Thank you for your reply despite being busy.
The BSP version is the same as my environment.
I’m also using 6.12.34_2.1.0 now. However, the issue has not been resolved yet.
I’m looking forward to receiving the other two pieces of information.
best regards
2,418件の閲覧回数
Rita_Wang
I am on the new prodcut training this week, I will try again next week when I go to office, then test for you. Thanks.
3,816件の閲覧回数
kazuhito_morita
@Rita_Wang
Thank you for your response.
The box is labeled as follows:
iMX95 Verdin EVK V1.1D
PN: 05241103
SN: 36204509
The board itself is labeled as follows:
iMX95 Verdin EVK CB V1.3A
PN:05211300
SN:35873003
best regards
3,844件の閲覧回数
kazuhito_morita
@Rita_Wang
PN: 05241103
SN: 36204509
PN:05211300
SN:35873003
best regards
3,790件の閲覧回数
Rita_Wang
3,984件の閲覧回数
kazuhito_morita
I tried to capture an image using v4l2-ctl, then the kernel crashed.
■ System Configuration
  • SoC / Board: NXP i.MX95 19x19 EVK (Verdin variant)
  • Linux Kernel: 6.6.23-lts-next-06236-gb586a521770e
  • NXP Yocto BSP: Official NXP BSP (NXP’s Full Reference Image)
  • Camera: OS08A20_MIPI
  • Used device: /dev/video0
  • Device Tree: imx95-19x19-verdin.dtb + imx95-19x19-verdin-lt8912.dtbo + imx95-19x19-verdin-os08a20.dtbo(overlayed)
  • media-ctl version: 6.6.23
■ Problem Description
When I try to start a video capture using the following command, the kernel crashes (Oops) every time.
  v4l2-ctl -d /dev/video0 --stream-mmap=1 --stream-count=1
■ Example Oops/Crash Log
Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP
CPU: 1 PID: 691 Comm: v4l2-ctl Not tainted 6.6.23-lts-next-06236-gb586a521770e #1
Hardware name: NXP i.MX95 19X19 board (DT)
pc : formatter_subdev_enable_streams+0xb0/0x22c
Call trace:
v4l2_subdev_enable_streams+0xe4/0x268
mxc_isi_crossbar_enable_streams+0x12c/0x1d0
mxc_isi_pipe_enable+0x204/0x2ac
mxc_isi_vb2_start_streaming+0xa0/0xe4
vb2_start_streaming+0x68/0x15c
vb2_core_streamon+0xf8/0x1bc
vb2_streamon+0x18/0x64
mxc_isi_video_streamon+0x28c/0x314
v4l_streamon+0x24/0x30
__video_do_ioctl+0x32c/0x3f8
■ media-ctl device topology (excerpt)
The media graph is active with crossbar/csi/formatter/ISI routing.
(See attached details below. media-ctl.txt)
■ Reproduction Details
  • The media graph, Device Tree, and v4l2/fmt settings are configured according to the official NXP documentation.
  • Even when restricting to just one ISI channel (/dev/video0), the Oops always occurs.
■ Questions
  • Is this Oops in formatter_subdev_enable_streams() a known issue in recent NXP BSP or kernel 6.6.x?
  • Is there any BSP update or kernel patch available to address this problem? If so, where can I find it?
  • Are there any recommended workarounds or hints to resolve this and enable video capture?
%3CLINGO-SUB%20id%3D%22lingo-sub-2170756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOS08A20%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%92HDMI(LT8912)%E7%B5%8C%E7%94%B1%E3%81%A7%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20OS08A20%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%A7%E6%92%AE%E5%BD%B1%E3%81%97%E3%81%9F%E6%98%A0%E5%83%8F%E3%82%92HDMI(LT8912)%E7%B5%8C%E7%94%B1%E3%81%A7%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1975524769%22%20id%3D%22toc-hId-1999684249%22%20id%3D%22toc-hId-1999684249%22%3E%E2%96%A0%20%E7%92%B0%E5%A2%83%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%3A%20i.MX95%20Verdin%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%82%AB%E3%83%A1%E3%83%A9%3C%2FSTRONG%3E%3A%20OS08A20%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EHDMI%3C%2FSTRONG%3E%20%3A%20LT8912%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EBSP%3C%2FSTRONG%3E%20%3A%20NXP%20%E5%85%AC%E5%BC%8F%20BSP%20(NXP%20%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E5%8F%82%E7%85%A7%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8)%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.23_2.0.0_MX95%26amp%3BappType%3Dlicense%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20ugc%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.23_2.0.0_MX95%26amp%3BappType%3Dlicense%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EDTB%3C%2FSTRONG%3E%20%3Aimx95-19x19-verdin.dtb%2Bimx95-19x19-verdin-lt8912.dtbo%2Bimx95-19x19-verdin-os08a20.dtbo%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FSTRONG%3E%3A%3C%2FLI%3E%3C%2FUL%3E%3CP%3EGST_DEBUG%3D3%20gst-launch-1.0v4l2src%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3D%2Fdev%2Fvideo0%20!%E3%80%8C%E3%83%93%E3%83%87%E3%82%AA%2Fx-raw%E3%80%81%E5%B9%85%3D1920%E3%80%81%E9%AB%98%E3%81%95%3D1080%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DYUYV%E3%80%8D!%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%EF%BC%81%E3%82%AA%E3%83%BC%E3%83%88%E3%83%93%E3%83%87%E3%82%AA%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E2%96%A0%20%E7%B5%90%E6%9E%9C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E0%3A00%3A00.083718541%20916%200xaaaaf3247f20%20%E3%82%A8%E3%83%A9%E3%83%BC%20GST_PIPELINE%20grammar.y%3A1138%3Agst_parse_perform_link%3Av4l2src0%20%E3%82%92%20videoconvert0%20%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E8%A6%81%E7%B4%A0%E3%82%82%20caps%20video%2Fx-raw%20%E3%82%92%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%B9%85%20%3D%20(int)%201920%E3%80%81%E9%AB%98%E3%81%95%20%3D%20(int)%201080%E3%80%81%E5%BD%A2%E5%BC%8F%20%3D%20(string)%20YUYV%20%E8%AD%A6%E5%91%8A%3A%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E8%AA%A4%E3%82%8A%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%20v4l2src0%20%E3%82%92%20videoconvert0%20%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E8%A6%81%E7%B4%A0%E3%82%82%20caps%20video%2Fx-raw%20%E3%82%92%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%B9%85%20%3D%20(int)%201920%E3%80%81%E9%AB%98%E3%81%95%20%3D%20(int)%201080%E3%80%81%E5%BD%A2%E5%BC%8F%20%3D%20(string)%20YUYV%3C%2FP%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2170756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2206716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254896%22%20target%3D%22_blank%22%3E%40zuhito_morita%3C%2FA%3E%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BDtb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%9Afdtfile%3Dimx95-19x19-evk-os08a20-isp-it6263-lvds0.dtb%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rita_Wang_0-1763459515691.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rita_Wang_0-1763459515691.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rita_Wang_0-1763459515691.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F366101i77C920D271FB9139%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rita_Wang_0-1763459515691.png%22%20alt%3D%22Rita_Wang_0-1763459515691.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E5%87%BA%E5%8A%9B%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9-ctl%20-p%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FLI%3E%0A%3CLI%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E5%87%BA%E5%8A%9B%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%2Fproc%2Fconfig.gz%20%E3%82%92%20zcat%20%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%81%B4%E3%81%A7%E3%81%BE%E3%81%A0%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%89%8D%E5%9B%9E%E5%85%B1%E6%9C%89%E3%81%97%E3%81%9F%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%89%8B%E5%85%83%E3%81%AB%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%BD%93%E7%A4%BE%E5%81%B4%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81iMX95%20Verdin%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fwww.toradex.com%2Fsupport%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EToradex%E3%81%AB%3C%2FA%3E%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.toradex.com%2Fsupport%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EToradex%20-%20%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%83%BC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%82%BF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2206475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%8A%E5%BF%99%E3%81%97%E3%81%84%E4%B8%AD%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EBSP%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%82%826.12.34_2.1.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E4%BB%8A%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%BE%E3%81%A0%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AE%8B%E3%82%8A%E3%81%AE2%E3%81%A4%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%82%E6%A5%BD%E3%81%97%E3%81%BF%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2206453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%AE%E3%82%A6%E3%82%A7%E3%83%96%E3%82%B5%E3%82%A4%E3%83%88%E3%81%A7%E3%81%AF%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%20BSP%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rita_Wang_0-1763443857800.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rita_Wang_0-1763443857800.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rita_Wang_0-1763443857800.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F366028iDBD9F0AB7E3E9C07%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rita_Wang_0-1763443857800.png%22%20alt%3D%22Rita_Wang_0-1763443857800.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%96%E3%81%AE%E4%BA%BA%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9-ctl%20-p%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E5%87%BA%E5%8A%9B%3C%2FLI%3E%0A%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9Fzcat%20%2Fproc%2Fconfig.gz%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E5%87%BA%E5%8A%9B%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E5%BE%8C%E3%81%BB%E3%81%A9%E5%BC%8A%E7%A4%BE%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%89%8B%E6%8C%81%E3%81%A1%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%9A%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%8A%E9%80%B1%E3%81%AF%E6%96%B0%E8%A3%BD%E5%93%81%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%92%E5%8F%97%E3%81%91%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9D%A5%E9%80%B1%E3%82%AA%E3%83%95%E3%82%A3%E3%82%B9%E3%81%AB%E8%A1%8C%E3%81%A3%E3%81%9F%E3%82%89%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BNSP-BSP%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FLI%3E%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9-ctl%20-p%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E5%87%BA%E5%8A%9B%3C%2FLI%3E%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9Fzcat%20%2Fproc%2Fconfig.gz%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E5%87%BA%E5%8A%9B%3C%2FLI%3E%3CLI%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BDTS%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%89%AF%E3%81%84%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%E4%BB%8A%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9D%A5%E9%80%B1%E3%82%AA%E3%83%95%E3%82%A3%E3%82%B9%E3%81%AB%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%8B%E3%82%89%E5%85%B1%E6%9C%89%E3%81%97%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%8A%E9%80%81%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E7%9A%86%E6%A7%98%E3%81%8B%E3%82%89%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%BF%83%E3%82%88%E3%82%8A%E6%84%9F%E8%AC%9D%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EOS08A20%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8B%E3%82%89%E3%81%AE%E5%85%A5%E5%8A%9B%E7%94%BB%E5%83%8F%E3%82%92HDMI%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E5%AE%9F%E8%A3%85%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BNSP-BSP%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FLI%3E%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%3CSTRONG%3E%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9-ctl%20-p%3C%2FSTRONG%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E5%87%BA%E5%8A%9B%3C%2FLI%3E%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%3CSTRONG%3Ezcat%20%2Fproc%2Fconfig.gz%3C%2FSTRONG%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E5%87%BA%E5%8A%9B%3C%2FLI%3E%3CLI%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BDTS%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254896%22%20target%3D%22_blank%22%3E%40zuhito_morita%3C%2FA%3E%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%89%8B%E5%85%83%E3%81%AB%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%BD%93%E7%A4%BE%E5%81%B4%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81iMX95%20Verdin%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fwww.toradex.com%2Fsupport%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EToradex%E3%81%AB%3C%2FA%3E%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.toradex.com%2Fsupport%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EToradex%20-%20%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%83%BC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%82%BF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2188737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2188737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%82%BF%E3%83%BB%E3%83%AF%E3%83%B3%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%BE%E3%81%A0%E3%82%AB%E3%83%A1%E3%83%A9%E7%94%BB%E5%83%8F%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E6%89%8B%E9%A0%86%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%3C!--%20%20ScriptorStartFragment%20%20--%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CEM%3E%3CFONT%20color%3D%22%23000000%22%3ELIBCAMERA_PIPELINES_MATCH_LIST%3D'nxp%2Fneo%2Cimx8-isi%2Cuvcvideo'%20%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CEM%3E%3CFONT%20color%3D%22%23000000%22%3EGST_DEBUG%3D3%20gst-launch-1.0%20libcamerasrc%20!%E5%88%97%20%EF%BC%81%3C%2FFONT%3E%3C%2FEM%3E%3CSPAN%3E%3CEM%3E%3CFONT%20color%3D%22%23000000%22%3E%E3%82%AA%E3%83%BC%E3%83%88%E3%83%93%E3%83%87%E3%82%AA%E3%82%B7%E3%83%B3%E3%82%AF%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FEM%3E%3C!--%20%20ScriptorEndFragment%20%20--%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%3CEM%3E%3CFONT%20color%3D%22%23000000%22%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FEM%3E%3CFONT%20color%3D%22%23000000%22%3E%E7%B5%90%E6%9E%9C%3C%2FFONT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CFONT%20color%3D%22%23000000%22%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E6%AC%A1%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CEM%3E%3CFONT%20color%3D%22%23000000%22%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20LIBCAMERA_PIPELINES_MATCH_LIST%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%3D'nxp%2Fneo%2Cimx8%3CBR%20%2F%3E%20%5B0%3A01%3A38.381866712%5D%5B780%5D%20%E6%83%85%E5%A0%B1%20%E3%82%AB%E3%83%A1%E3%83%A9%20camera_manager.cpp%3A326libcamera%20v0.0.0%2B5937-lf-6.12.34-2.1.0%3CBR%20%2F%3E%5B0%3A01%3A38.507243420%5D%5B784%5D%20%E6%83%85%E5%A0%B1%20NxpNeoIPA%20neo_ipa.cpp%3A131nxpneo%3A%20IPANxpNeo%20NXPNEO_IPA_v0.0.0%2B5937-lf-6.12.34-2.1.0%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%83%A9%E3%82%A4%E3%83%96%E3%81%AA%E3%81%AE%E3%81%A7%20PREROLL%20%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%3CBR%20%2F%3E%200%3A00%3A00.611470375%20780%200xffff84000b70%20FIXME%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20gstutils.c%3A4169%3Agst_element_decorate_stream_id_internal%3A%3CLIBCAMERASRC0%3E%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0ID%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0ID%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%87%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8B%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AA%E6%96%B9%E6%B3%95%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E4%BA%8B%E5%89%8D%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%86%8D%E7%94%9F%E4%B8%AD%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%200%3A00%3A00.612225292%20780%200xffff84000b70%20%E8%AD%A6%E5%91%8A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20gstlibcamera-utils.cpp%3A345%3Agst_libcamera_stream_formats_to_caps%3A%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84DRM%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88R10%3CBR%20%2F%3E%E6%96%B0%E3%81%97%E3%81%84%E6%99%82%E8%A8%88%3A%20GstSystemClock%3CBR%20%2F%3E%200%3A00%3A00.612294792%20780%200xffff84000b70%20%E8%AD%A6%E5%91%8A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20gstlibcamera-utils.cpp%3A345%3Agst_libcamera_stream_formats_to_caps%3A%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84DRM%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88R12%3CBR%20%2F%3E%200%3A00%3A00.612571875%20780%200xffff84000b70%20%E8%AD%A6%E5%91%8A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20gstlibcamera-utils.cpp%3A345%3Agst_libcamera_stream_formats_to_caps%3A%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84DRM%E5%BD%A2%E5%BC%8FXVUY%3CBR%20%2F%3E%20%5B0%3A01%3A38.925148004%5D%5B785%5D%20INFO%20%E3%82%AB%E3%83%A1%E3%83%A9%20camera.cpp%3A1205%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%AE%E8%A8%AD%E5%AE%9A%3A%20(0)%203840x2160-NV21%2FsYCC%3C%2FLIBCAMERASRC0%3E%3C%2FFONT%3E%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CEM%3E%3CFONT%20color%3D%22%23000000%22%3E0%3A00%3A00.0%20%2F%2099%3A99%3A99.%3A99.%3C%2FFONT%3E%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AF%200%3A00%3A00.0%20%E3%81%AE%E3%81%BE%E3%81%BE%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3ENXP%20BSP%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Weston%20%E3%81%8C%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%81%B0%E8%89%B2%E3%81%AE%E8%83%8C%E6%99%AF%E3%81%A8%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%82%A2%E3%82%A4%E3%82%B3%E3%83%B3%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254896%22%20target%3D%22_blank%22%3E%40zuhito_morita%3C%2FA%3E%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%88%BB%E3%81%A3%E3%81%A6%3CSPAN%20data-slate-fragment%3D%22JTVCJTdCJTIydHlwZSUyMiUzQSUyMnBhcmFncmFwaCUyMiUyQyUyMmNoaWxkcmVuJTIyJTNBJTVCJTdCJTIyaWQlMjIlM0ElMjJsTjVPOURHV3FKJTIyJTJDJTIycGFyYUlkeCUyMiUzQTAlMkMlMjJzcmMlMjIlM0ElMjJjb2xsZWFndWUlMjIlMkMlMjJkc3QlMjIlM0ElMjIlRTUlOTAlOEMlRTQlQkElOEIlMjIlMkMlMjJtZXRhZGF0YSUyMiUzQSUyMiUyMiUyQyUyMm1hdGNoZXMlMjIlM0FudWxsJTJDJTIydHJhbnNsYXRlZEJ5JTIyJTNBbnVsbCUyQyUyMm1ldGFEYXRhJTIyJTNBJTVCJTVEJTJDJTIydGV4dCUyMiUzQSUyMmNvbGxlYWd1ZSUyMiU3RCU1RCU3RCU1RA%3D%3D%22%3E%E5%90%8C%E5%83%9A%E3%81%A8%E8%A9%B1%E3%81%97%E5%90%88%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%82%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ELIBCAMERA_PIPELINES_MATCH_LIST%3D'nxp%2Fneo%2Cimx8-isi%2Cuvcvideo'%20%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9C%E3%81%B2%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8B%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%82%BF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2179675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%82%BF%E3%83%BB%E3%83%AF%E3%83%B3%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%9E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E4%BC%91%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254896%22%20target%3D%22_blank%22%3E%40zuhito_morita%3C%2FA%3E%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E5%BD%93%E7%A4%BE%E3%81%AE%20EVK%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E5%BD%93%E7%A4%BE%E3%81%AE%20EVK%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%20HDMI%20%E7%B5%8C%E7%94%B1%E3%81%A7%20OS08A20%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%80%81%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81%E4%B8%AD%E5%9B%BD%E3%81%A7%E3%81%AF%E4%BB%8A%E6%97%A5%E3%81%8B%E3%82%89%E5%9B%BD%E6%85%B6%E7%AF%80%E3%81%AE%E4%BC%91%E6%9A%87%E3%81%A8%E3%81%AA%E3%82%8A%E3%80%8110%E6%9C%889%E6%97%A5%E3%81%AB%E3%82%AA%E3%83%95%E3%82%A3%E3%82%B9%E3%81%AB%E6%88%BB%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E6%96%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E7%90%86%E8%A7%A3%E3%81%AE%E3%81%BB%E3%81%A9%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%82%BF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%99%E7%9C%9F%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%9C%E3%81%B2%E3%81%94%E8%A6%A7%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%80%81%E3%81%94%E6%84%9F%E6%83%B3%E3%82%92%E3%81%8A%E8%81%9E%E3%81%8B%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254896%22%20target%3D%22_blank%22%3E%40zuhito_morita%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%99%E7%9C%9F%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%81%B4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%20B0%20%E3%81%8B%20A1%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%AA%E3%82%BF%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%82%BF%E3%83%BB%E3%83%AF%E3%83%B3%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%9F%20GStreamer%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx95evk%3A~%23%20gst-launch-1.0%20libcamerasrc%20!%20queue%20!%20autovideosink%0ASetting%20pipeline%20to%20PAUSED%20...%0A%5B0%3A01%3A47.980555800%5D%20%5B624%5D%20%20INFO%20Camera%20camera_manager.cpp%3A315%20libcamera%20v0.0.0%2B4594-lf-6.6.23-2.0.0-dirty%20(2025-09-05T01%3A32%3A47%2B00%3A00)%0A%5B0%3A01%3A48.031624883%5D%20%5B629%5D%20%20INFO%20NxpNeo%20neo_utils.cpp%3A629%20Parsing%20pipeline%20config%20file%20%2Fusr%2Fshare%2Flibcamera%2Fpipeline%2Fnxp%2Fneo%2Fconfig.yaml%0A%5B0%3A01%3A48.033805175%5D%20%5B629%5D%20%20WARN%20CameraSensor%20camera_sensor.cpp%3A248%20'os08a20%202-0036'%3A%20Recommended%20V4L2%20control%200x009a0922%20not%20supported%0A%5B0%3A01%3A48.033880508%5D%20%5B629%5D%20%20WARN%20CameraSensor%20camera_sensor.cpp%3A315%20'os08a20%202-0036'%3A%20The%20sensor%20kernel%20driver%20needs%20to%20be%20fixed%0A%5B0%3A01%3A48.033911467%5D%20%5B629%5D%20%20WARN%20CameraSensor%20camera_sensor.cpp%3A317%20'os08a20%202-0036'%3A%20See%20Documentation%2Fsensor_driver_requirements.rst%20in%20the%20libcamera%20sources%20for%20more%20information%0A%5B0%3A01%3A48.034876550%5D%20%5B629%5D%20%20WARN%20CameraSensorProperties%20camera_sensor_properties.cpp%3A262%20No%20static%20properties%20available%20for%20'os08a20'%0A%5B0%3A01%3A48.034923050%5D%20%5B629%5D%20%20WARN%20CameraSensorProperties%20camera_sensor_properties.cpp%3A264%20Please%20consider%20updating%20the%20camera%20sensor%20properties%20database%0A%5B0%3A01%3A48.034952592%5D%20%5B629%5D%20%20WARN%20CameraSensor%20camera_sensor.cpp%3A461%20'os08a20%202-0036'%3A%20Failed%20to%20retrieve%20the%20camera%20location%0A%5B0%3A01%3A48.034980800%5D%20%5B629%5D%20%20WARN%20CameraSensor%20camera_sensor.cpp%3A483%20'os08a20%202-0036'%3A%20Rotation%20control%20not%20available%2C%20default%20to%200%20degrees%0APipeline%20is%20live%20and%20does%20not%20need%20PREROLL%20...%0AERROR%3A%20from%20element%20%2FGstPipeline%3Apipeline0%2FGstLibcameraSrc%3Alibcamerasrc0%3A%20Internal%20data%20stream%20error.%0APipeline%20is%20PREROLLED%20...%0AAdditional%20debug%20info%3A%0A%2Fusr%2Fsrc%2Fdebug%2Flibcamera%2F0.2.0.imx%2Fsrc%2Fgstreamer%2Fgstlibcamerasrc.cpp(645)%3A%20gst_libcamera_src_task_enter%20()%3A%20%2FGstPipeline%3Apipeline0%2FGstLibcameraSrc%3Alibcamerasrc0%3A%0Astreaming%20stopped%2C%20reason%20not-negotiated%20(-4)%0ASetting%20pipeline%20to%20PLAYING%20...%0AERROR%3A%20pipeline%20doesn't%20want%20to%20preroll.%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E4%BB%96%E3%81%AB%E8%A9%A6%E3%81%99%E3%81%B9%E3%81%8D%E3%81%93%E3%81%A8%E3%82%84%E7%A2%BA%E8%AA%8D%E3%81%99%E3%81%B9%E3%81%8D%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E6.12.20_2.0.0%20BSP%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20i.MX%2095%20EVK%20%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%20Gstreamer%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx95evk%3A~%23%20gst-launch-1.0%20libcamerasrc%20!%20queue%20!%20autovideosink%0A%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%99%E7%9C%9F%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%82%BF%E3%83%BB%E3%83%AF%E3%83%B3%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%A9%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CSTRONG%3EiMX95%20%E3%83%B4%E3%82%A7%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%20EVK%20V1.1D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EPN%3A%2005241103%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3A%2036204509%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E8%87%AA%E4%BD%93%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%A9%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CSTRONG%3EiMX95%20%E3%83%B4%E3%82%A7%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%20EVK%20CB%20V1.3A%3CBR%20%2F%3E%3CSPAN%3E%E5%93%81%E7%95%AA%EF%BC%9A05211300%3CBR%20%2F%3E%3C%2FSPAN%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%EF%BC%9A35873003%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%82%BF%E3%83%BB%E3%83%AF%E3%83%B3%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%A9%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CSTRONG%3EiMX95%20%E3%83%B4%E3%82%A7%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%20EVK%20V1.1D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EPN%3A%2005241103%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3A%2036204509%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E8%87%AA%E4%BD%93%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%A9%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CSTRONG%3EiMX95%20%E3%83%B4%E3%82%A7%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%20EVK%20CB%20V1.3A%3CBR%20%2F%3E%E5%93%81%E7%95%AA%EF%BC%9A05211300%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%EF%BC%9A35873003%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2173385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2173385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Ei.MX95%2019x19%20EVK%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81B0%20%E3%81%BE%E3%81%9F%E3%81%AF%E4%BB%96%E3%81%AE%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ev4l2-ctl%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1975552610%22%20id%3D%22toc-hId-192229786%22%20id%3D%22toc-hId-192229786%22%3E%E2%96%A0%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%A7%8B%E6%88%90%3C%2FH3%3E%3CUL%3E%3CLI%3ESoC%20%2F%20%E3%83%9C%E3%83%BC%E3%83%89%3A%20NXP%20i.MX95%2019x19%20EVK%20(Verdin%20%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88)%3C%2FLI%3E%3CLI%3ELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3A%206.6.23-lts-next-06236-gb586a521770e%3C%2FLI%3E%3CLI%3ENXP%20Yocto%20BSP%3A%20%3CSPAN%3ENXP%20%E5%85%AC%E5%BC%8F%20BSP%20(NXP%20%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E5%8F%82%E7%85%A7%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8)%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E3%82%AB%E3%83%A1%E3%83%A9%3A%20OS08A20_MIPI%3C%2FLI%3E%3CLI%3E%E4%BD%BF%E7%94%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%20%2Fdev%2Fvideo0%3C%2FLI%3E%3CLI%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%3A%20%3CSPAN%3Eimx95-19x19-verdin.dtb%20%2B%20imx95-19x19-verdin-lt8912.dtbo%20%2B%20imx95-19x19-verdin-os08a20.dtbo%3C%2FSPAN%3E%20(%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4)%3C%2FLI%3E%3CLI%3E%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9-ctl%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%206.6.23%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-168098147%22%20id%3D%22toc-hId--1615224677%22%20id%3D%22toc-hId--1615224677%22%3E%E2%96%A0%20%E5%95%8F%E9%A1%8C%E3%81%AE%E8%AA%AC%E6%98%8E%3C%2FH3%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E6%AF%8E%E5%9B%9E%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%20(%E3%81%8A%E3%81%A3%E3%81%A8)%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Ev4l2-ctl%20-d%20%2Fdev%2Fvideo0%20--stream-mmap%3D1%20--stream-count%3D1%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CH3%20id%3D%22toc-hId--1639356316%22%20id%3D%22toc-hId-872288156%22%20id%3D%22toc-hId-872288156%22%3E%E2%96%A0%20%E5%A4%B1%E6%95%97%2F%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%82%B0%E3%81%AE%E4%BE%8B%3C%2FH3%3E%3CBLOCKQUOTE%3E%3CP%3E%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%200000000096000004%20%5B%231%5D%20PREEMPT%20SMP%3CBR%20%2F%3E%20CPU%3A%201%20PID%3A%20691%20%E9%80%9A%E4%BF%A1%3A%20v4l2-ctl%20%E6%B1%9A%E6%9F%93%E3%81%AA%E3%81%97%206.6.23-lts-next-06236-gb586a521770e%EF%BC%831%3CBR%20%2F%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%90%8D%3A%20NXP%20i.MX95%2019X19%20%E3%83%9C%E3%83%BC%E3%83%89%20(DT)%3CBR%20%2F%3E%20pc%3A%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%82%BF_subdev_enable_streams%2B0xb0%2F0x22c%3CBR%20%2F%3E%20...%3CBR%20%2F%3E%E9%80%9A%E8%A9%B1%E5%B1%A5%E6%AD%B4%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%82%BF_subdev_enable_streams%2B0xb0%2F0x22c%3CBR%20%2F%3E%20v4l2_subdev_enable_streams%2B0xe4%2F0x268%3CBR%20%2F%3E%20mxc_isi_crossbar_enable_streams%2B0x12c%2F0x1d0%3CBR%20%2F%3E%20v4l2_subdev_enable_streams%2B0xe4%2F0x268%3CBR%20%2F%3E%20mxc_isi_pipe_enable%2B0x204%2F0x2ac%3CBR%20%2F%3E%20mxc_isi_vb2_start_streaming%2B0xa0%2F0xe4%3CBR%20%2F%3E%20vb2_start_streaming%2B0x68%2F0x15c%3CBR%20%2F%3E%20vb2_core_streamon%2B0xf8%2F0x1bc%3CBR%20%2F%3E%20vb2_streamon%2B0x18%2F0x64%3CBR%20%2F%3E%20mxc_isi_video_streamon%2B0x28c%2F0x314%3CBR%20%2F%3E%20v4l_streamon%2B0x24%2F0x30%3CBR%20%2F%3E%20__video_do_ioctl%2B0x32c%2F0x3f8%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CH3%20id%3D%22toc-hId-848156517%22%20id%3D%22toc-hId--935166307%22%20id%3D%22toc-hId--935166307%22%3E%E2%96%A0%20%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9-ctl%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%88%E3%83%9D%E3%83%AD%E3%82%B8%EF%BC%88%E6%8A%9C%E7%B2%8B%EF%BC%89%3C%2FH3%3E%3CP%3E%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20%E3%82%B0%E3%83%A9%E3%83%95%E3%81%AF%E3%80%81%E3%82%AF%E3%83%AD%E3%82%B9%E3%83%90%E3%83%BC%2FCSI%2F%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%82%BF%2FISI%20%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%A7%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E(%E4%B8%8B%E8%A8%98%E3%81%AE%E6%B7%BB%E4%BB%98%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9-ctl.txt)%3CBR%20%2F%3E...%3C%2FP%3E%3CH3%20id%3D%22toc-hId--959297946%22%20id%3D%22toc-hId-1552346526%22%20id%3D%22toc-hId-1552346526%22%3E%E2%96%A0%20%E8%A4%87%E8%A3%BD%E8%A9%B3%E7%B4%B0%3C%2FH3%3E%3CUL%3E%3CLI%3E%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%20%E3%82%B0%E3%83%A9%E3%83%95%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%80%81v4l2%2Ffmt%20%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%80%81NXP%20%E3%81%AE%E5%85%AC%E5%BC%8F%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E1%20%E3%81%A4%E3%81%AE%20ISI%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20(%2Fdev%2Fvideo0)%20%E3%81%AB%E5%88%B6%E9%99%90%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%80%81Oops%20%E3%81%AF%E5%B8%B8%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-1528214887%22%20id%3D%22toc-hId--255107937%22%20id%3D%22toc-hId--255107937%22%3E%E2%96%A0%20%E8%B3%AA%E5%95%8F%3C%2FH3%3E%3CUL%3E%3CLI%3Eformatter_subdev_enable_streams()%20%E3%81%AE%E3%81%93%E3%81%AE%20Oops%20%E3%81%AF%E3%80%81%E6%9C%80%E8%BF%91%E3%81%AE%20NXP%20BSP%20%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%206.6.x%20%E3%81%AE%E6%97%A2%E7%9F%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%20BSP%20%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%82%E3%81%97SO%E3%81%AA%E3%82%89%E3%80%81%E3%81%A9%E3%81%93%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E5%9B%9E%E9%81%BF%E7%AD%96%E3%82%84%E3%83%92%E3%83%B3%E3%83%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20display%20video%20capture%20by%20OS08A20%20camera%20via%20HDMI(LT8912)%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%E3%80%81%3CBR%20%2F%3E%E7%A7%81%E3%82%82%20iMX95%20Verdin%20EVK%20%E3%82%AD%E3%83%83%E3%83%88%E3%81%A7%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E%E6%9C%80%E8%BF%91%E3%80%81%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2F4K-MIPI-CMOS-CAMERA-MODULE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2F4K-MIPI-CMOS-CAMERA-MODULE%20%E3%81%8B%E3%82%89%3C%2FA%3E%3CSPAN%3E%20X-IMX-OS08A20%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%82%92%20iMX95%20Verdin%20EVK%20%E3%82%AD%E3%83%83%E3%83%88%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AEdtb%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSTRONG%3E-%20imx95-19x19-verdin-os08a20-isp-lt8912.dtb%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E3%81%AEv4l2%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81stream-mmap%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7v4l2%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-l%20%22'os08a20%202-0036'%3A0%20-%26gt%3B%20'csidev-4ad30000.csi'%3A0%5B1%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-l%20%22'csidev-4ad30000.csi'%3A1%20-%26gt%3B%20'4ac10000.syscon%3Aformatter%4020'%3A0%5B1%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-l%20%22'4ac10000.syscon%3Aformatter%4020'%3A1%20-%26gt%3B%20'crossbar'%3A2%5B1%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-l%20%22'%E3%82%AF%E3%83%AD%E3%82%B9%E3%83%90%E3%83%BC'%3A5%20-%26gt%3B%20'mxc_isi.0'%3A0%5B1%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-l%20%22'mxc_isi.0'%3A1%20-%26gt%3B%20'mxc_isi.0.capture'%3A0%5B1%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Eecho%20%22%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E8%A8%AD%E5%AE%9A%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-R%20%22'os08a20%202-0036'%20%5B1%2F0-%26gt%3B0%2F0%5B1%5D%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-R%20%22'csidev-4ad30000.csi'%20%5B0%2F0-%26gt%3B1%2F0%5B1%5D%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-R%20%22'4ac10000.syscon%3Aformatter%4020'%20%5B0%2F0-%26gt%3B1%2F0%5B1%5D%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-R%20%22'%E3%82%AF%E3%83%AD%E3%82%B9%E3%83%90%E3%83%BC'%20%5B2%2F0-%26gt%3B5%2F0%5B1%5D%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Eecho%20%22%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E5%AE%8C%E4%BA%86%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-V%20%22'os08a20%202-0036'%3A0%2F0%20%5Bfmt%3ASBGGR10%2F3840x2160%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%3A%E3%81%AA%E3%81%97%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-V%20%22'csidev-4ad30000.csi'%3A0%2F0%20%5Bfmt%3ASBGGR10%2F3840x2160%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%3A%E3%81%AA%E3%81%97%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-V%20%22'4ac10000.syscon%3Aformatter%4020'%3A0%2F0%20%5Bfmt%3ASBGGR10%2F3840x2160%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%3A%E3%81%AA%E3%81%97%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-V%20%22'%E3%82%AF%E3%83%AD%E3%82%B9%E3%83%90%E3%83%BC'%3A2%2F0%20%5Bfmt%3ASBGGR10%2F3840x2160%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%3A%E3%81%AA%E3%81%97%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emedia-ctl%20-d%20%2Fdev%2Fmedia0%20-V%20%22'mxc_isi.0'%3A0%2F0%20%5Bfmt%3ASBGGR10%2F3840x2160%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%3A%E3%81%AA%E3%81%97%5D%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Eecho%20%22%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%20v4l2%20%E3%81%A7%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%2030%20fps%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3Ev4l2-ctl%20-d%20%2Fdev%2Fvideo0%20--set-fmt-video%3D%E5%B9%85%3D3840%E3%80%81%E9%AB%98%E3%81%95%3D2160%E3%80%81%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3DBG10%20--stream-mmap%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%2030.04%20fps%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%2030.04%20fps%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%26lt%3B%2030.04%20fps%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%E3%82%92%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Eroot%40imx95-19x19-verdin%3A~%23%20gst-launch-1.0%20libcamerasrc%20!%20video%2Fx-raw%2Cformat%3DBGRx%2Cwidth%3D3840%2Cheight%3D2160%20!%20videoconvert%20!%20fpsdisplaysink%20video-sink%3Dautovideosink%20text-overlay%3Dtrue%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B0%3A01%3A33.994814097%5D%20%5B774%5D%20%E6%83%85%E5%A0%B1%20%E3%82%AB%E3%83%A1%E3%83%A9%20camera_manager.cpp%3A326%20libcamera%20v0.5.0%2B330-7fce0333-dirty%20(2025-06-04T12%3A23%3A54UTC)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%83%A9%E3%82%A4%E3%83%96%E3%81%AA%E3%81%AE%E3%81%A7%20PREROLL%20%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B0%3A01%3A34.098980249%5D%20%5B780%5D%20%E8%AD%A6%E5%91%8A%20ISI%20imx8-isi.cpp%3A353%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BYUV%2FRGB%E5%BD%A2%E5%BC%8F%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E4%BA%8B%E5%89%8D%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%86%8D%E7%94%9F%E4%B8%AD%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E8%A6%81%E7%B4%A0%20%2FGstPipeline%3Apipeline0%2FGstLibcameraSrc%3Alibcamerasrc0%20%E3%81%8B%E3%82%89%3A%20%E5%86%85%E9%83%A8%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%83%85%E5%A0%B1%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E%2Fusr%2Fsrc%2Fdebug%2Flibcamera%2F0.5.0.imx%2Fsrc%2Fgstreamer%2Fgstlibcamerasrc.cpp(682)%3A%20gst_libcamera_src_task_enter()%3A%20%2FGstPipeline%3Apipeline0%2FGstLibcameraSrc%3Alibcamerasrc0%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%90%86%E7%94%B1%E3%81%AF%E4%BA%A4%E6%B8%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(-4)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%83%97%E3%83%AA%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%AE%9F%E8%A1%8C%E3%81%AF0%3A00%3A00.000314034%E5%BE%8C%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%20NULL%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B0%3A01%3A34.099615025%5D%20%5B780%5D%20%E8%AD%A6%E5%91%8A%20ISI%20imx8-isi.cpp%3A353%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BYUV%2FRGB%E5%BD%A2%E5%BC%8F%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E8%A6%81%E7%B4%A0%20%2FGstPipeline%3Apipeline0%2FGstLibcameraSrc%3Alibcamerasrc0%20%E3%81%8B%E3%82%89%3A%20%E5%86%85%E9%83%A8%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%83%85%E5%A0%B1%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%2Fusr%2Fsrc%2Fdebug%2Flibcamera%2F0.5.0.imx%2Fsrc%2Fgstreamer%2Fgstlibcamerasrc.cpp(682)%3A%20gst_libcamera_src_task_enter()%3A%20%2FGstPipeline%3Apipeline0%2FGstLibcameraSrc%3Alibcamerasrc0%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%90%86%E7%94%B1%E3%81%AF%E4%BA%A4%E6%B8%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(-4)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3Ecam%20-c%201%20--info%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B0%3A01%3A09.047021603%5D%20%5B772%5D%20%E6%83%85%E5%A0%B1%20%E3%82%AB%E3%83%A1%E3%83%A9%20camera_manager.cpp%3A326%20libcamera%20v0.5.0%2B330-7fce0333-dirty%20(2025-06-04T12%3A23%3A54UTC)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B0%3A01%3A09.152506530%5D%20%5B772%5D%20%E8%AD%A6%E5%91%8A%20ISI%20imx8-isi.cpp%3A353%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BYUV%2FRGB%E5%BD%A2%E5%BC%8F%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%AB%E3%83%A1%E3%83%A9%20%2Fbase%2Fsoc%2Fbus%4042000000%2Fi2c%4042530000%2Fos08a20_mipi%4036%20%E3%82%92%20cam0%20%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E0%3A%203840x2160-SBGGR10%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E5%BD%A2%E5%BC%8F%3A%20SBGGR10%20(3840x2160)-(3840x2160)%2F(%2B1%2C%2B1)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E5%BD%A2%E5%BC%8F%3A%20SBGGR12%20(3840x2160)-(3840x2160)%2F(%2B1%2C%2B1)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%80%81libcamera%20%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%20MATCH_LIST%20%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%8C%E3%81%9D%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E5%BE%8C%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3ELIBCAMERA_PIPELINES_MATCH_LIST%3D'nxp%2Fneo%2Cimx8-isi'%20%E3%82%92%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSPAN%3Eroot%40imx95-19x19-verdin%3A~%23%20cam%20-c%201%20--info%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E%5B0%3A01%3A46.524765885%5D%20%5B782%5D%20%E6%83%85%E5%A0%B1%20%E3%82%AB%E3%83%A1%E3%83%A9%20camera_manager.cpp%3A326%20libcamera%20v0.5.0%2B330-7fce0333-dirty%20(2025-06-04T12%3A23%3A54UTC)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E%5B0%3A01%3A46.642824790%5D%20%5B783%5D%20%E6%83%85%E5%A0%B1%20NxpNeoIPA%20neo_ipa.cpp%3A128%20nxpneo%3A%20IPANxpNeo%20NXPNEO_IPA_v0.5.0%2B330-7fce0333-dirty%20(2025-06-04T12%3A23%3A54UTC)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%AB%E3%83%A1%E3%83%A9%20%2Fbase%2Fsoc%2Fbus%4042000000%2Fi2c%4042530000%2Fos08a20_mipi%4036%20%E3%82%92%20cam0%20%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E0%3A%203840x2160-BGR888%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20R8%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20R10%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20R12%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20R16%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20NV21%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20NV61%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20NV12%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20XBGR8888%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E5%BD%A2%E5%BC%8F%3A%20BGR888%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20RGB888%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20XRGB8888%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20NV16%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E5%BD%A2%E5%BC%8F%3A%20YUYV%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20XVUY8888%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E*%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%3A%20UYVY%20(1920x1080)-(3840x2160)%2F(%2B0%2C%2B0)%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%201920x1080%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E-%203840x2160%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AEgstreamer%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%82%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%E5%BC%B7%E5%88%B6%E7%B5%82%E4%BA%86%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E5%BF%9C%E7%AD%94%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3Eroot%40imx95-19x19-verdin%3A~%23%20GST_DEBUG%3D3%20gst-launch-1.0%20libcamerasrc%20!%E3%83%93%E3%83%87%E3%82%AA%E5%A4%89%E6%8F%9B%EF%BC%81%E3%82%AA%E3%83%BC%E3%83%88%E3%83%93%E3%83%87%E3%82%AA%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B0%3A04%3A17.443233635%5D%20%5B794%5D%20%E6%83%85%E5%A0%B1%20%E3%82%AB%E3%83%A1%E3%83%A9%20camera_manager.cpp%3A326%20libcamera%20v0.5.0%2B330-7fce0333-dirty%20(2025-06-04T12%3A23%3A54UTC)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B0%3A04%3A17.562332552%5D%20%5B798%5D%20%E6%83%85%E5%A0%B1%20NxpNeoIPA%20neo_ipa.cpp%3A128%20nxpneo%3A%20IPANxpNeo%20NXPNEO_IPA_v0.5.0%2B330-7fce0333-dirty%20(2025-06-04T12%3A23%3A54UTC)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%83%A9%E3%82%A4%E3%83%96%E3%81%AA%E3%81%AE%E3%81%A7%20PREROLL%20%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E0%3A00%3A00.203418021%20794%200xffffa4000b70%20FIXME%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20gstutils.c%3A4169%3Agst_element_decorate_stream_id_internal%3A%3CLIBCAMERASRC0%3E%20%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0ID%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0ID%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%87%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8B%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AA%E6%96%B9%E6%B3%95%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLIBCAMERASRC0%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E4%BA%8B%E5%89%8D%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%86%8D%E7%94%9F%E4%B8%AD%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E0%3A00%3A00.203987701%20794%200xffffa4000b70%20%E8%AD%A6%E5%91%8A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20gstlibcamera-utils.cpp%3A345%3Agst_libcamera_stream_formats_to_caps%3A%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%20DRM%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20R10%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E0%3A00%3A00.204038448%20794%200xffffa4000b70%20%E8%AD%A6%E5%91%8A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20gstlibcamera-utils.cpp%3A345%3Agst_libcamera_stream_formats_to_caps%3A%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%20DRM%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20R12%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E6%96%B0%E3%81%97%E3%81%84%E6%99%82%E8%A8%88%3A%20GstSystemClock%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E0%3A00%3A00.204228106%20794%200xffffa4000b70%20%E8%AD%A6%E5%91%8A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20gstlibcamera-utils.cpp%3A345%3Agst_libcamera_stream_formats_to_caps%3A%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%20DRM%20%E5%BD%A2%E5%BC%8F%20XVUY%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%5B0%3A04%3A17.578186764%5D%20%5B799%5D%20INFO%20%E3%82%AB%E3%83%A1%E3%83%A9%20camera.cpp%3A1205%20%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20(0)%203840x2160-NV21%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E0%3A00%3A00.0%20%2F%2099%3A99%3A99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E3%81%A9%E3%81%86%E3%82%84%E3%81%A3%E3%81%A6%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
