How to disable TZASC module in i.MX6ULL?
1,003 次查看
rahuldhobi
I have enable TZASC module by setting fuses in bootloader. I have enabled it by using following command.
fuse prog 0 6 0x10000000
Now I want to disable TZASC. How to disable it using fuse?
标记 (1)
955 次查看
igorpadykov
Hi Rahul
unfortunately burning fuse is irreversible operation and fuse can not be
restored to original state.
