How to directly operate registers in the application layer of IMX8QXP
zheliu
How to directly operate registers in the application layer of IMX8QXP? I use devmem or memtool to set and read register data, but it is not correct. Is there a special tool for IMX8QXP to read and write registers?
pengyong_zhang
Hi @zheliu
you can use the pinconf-pins to see the register value, But if you want to change it, There is no way to complete it in sysfs, you can modify it by dts file.
B.R
pengyong_zhang
Hi @zheliu
>>>Could you tell more about this incorrect, what register did you change?
B.R
zheliu
I want to read and write this register,
Use devmem to report bus error.
