How to debug using JTAG
2,637件の閲覧回数
BryanJI
How to setup an environment which I can use JTAG to debug the program?
Because when you first get a new design, you need to figure out the problem of your DDR2.
If you can't setup DDR2, nothing you can to to boot from SD, am I right?
Any solutions.
3 返答(返信)
2,429件の閲覧回数
RichardXiao
2,428件の閲覧回数
BryanJI
Before I use Linux BSP, I need to make sure my custom board running correctly. It is better I can use IRA or similar IDE with J-Link to figure out the reason. Possibly, DDR configuration error. It helps me to find the reason quickly and efficient.
Robert M Girard said:
Hello Bryan,
Are you using the Linux BSP for the i.MX28 EVK?
Robert G
2,429件の閲覧回数
RobertMGirard
Hello Bryan,
Robert G
