How to debug u-boot.imx by SD Card
road_wang
             My I.MX6UL system is running on SD Card,when I modify some codes on U-Boot code and generated new u-boot.imx,for cann't find u-boot.imx on the SD Card,how to update u-boot.imx on SD Card for debug.
Rita_Wang
Hi Wang,
If you modify the u-boot you need to download the new one to your board. You can use the mfgtool to download. If you are using the newest BSP you need to use the tool UUU.
Hope this can do help for you
Have a nice day
Best Regards
Rita
road_wang
but there isn't u-boot.imx on sdcard,I can't copy it to sdcard directly. How can update u-boot.imx on sdcard?
Rita_Wang
Hi Wang,
Have a nice day
Best Regards
Rita
road_wang
Hi Rita,
 Because my board nand flash size is only 256M,but the image build from Yocto project is larger than it,So I only use sdcard to debug now. Can update u-boot on SDCard?
Best Regards
Road
Rita_Wang
Yes, if your board support sdcard, you can use it.
