How to debug the LEC-IMX8MP
2,813 次查看
SegFault0
what are the options for debugging the Cortex-M7 on my LEC-IMX8MP modul. The datasheet from Adlink states that there should be a 30-pin Header with 5 pins for the JTAG interface. Unfortunately, that interface is missing on my modul. Are there any other options, like debugging from the Cortex-A or at least debug traces?
Edit: Adlink support supplied me with the pinout
2,802 次查看
joanxie
do you mean your board doesn't have any debug interface?
2,797 次查看
SegFault0
It technically does, but the 30-Pin header, of which 5 pins are reserved for JTAG are missing. I could solder them on myself, but Adlink does not supply a pinout or any schematics for the board, so I'm kind of lost.
On page 13 they state that there should be a connector, which is simply missing on my board.
LEC-IMX8Mplus User guide (adlinktech.com)
标记 (1)
2,783 次查看
joanxie
maybe you can refer to the chapter 9 Linux Remote Processor (RPROC) framework
"https://www.nxp.com.cn/docs/en/application-note/AN5317.pdf"
