How to debug failed kernel boot
1,416件の閲覧回数
ytanaka
I've built u-boot, dtb, zImage and rootfs using bitbake core-image-base. Then I wrote these images to emmc. But booting stopped after starting kernel. I attached the boot logs. How do I fix this case? Does anyone have any ideas?
Thank you,
ラベル(3)
1,398件の閲覧回数
jimmychan
Which board are you using?
Which version of BSP are you using?
According to your log, seems there are some pins conflict. Please check the IOMUX pins in your board device tree file.
