How to debug Linux console freeze
1,723件の閲覧回数
steve_dunnagan
I used Buildroot for the i.MX6UL EVK evaluation board, and that's working fine.  I'm using Buildroot for our i.MX6UL based product, and the kernel boots and I can login, but shortly after that the console hangs.
I've tried the following:
* Set ulimits in a start-up script.
* Blink an LED.  The LED stops blinking at about the same time as the console hangs.
* Check available memory; looks fine.
* Check /var/log/messages; looks fine.
* Check dmesg; nothing suspicious.
I'm hoping for suggestions on how to debug further.
Steve
1,672件の閲覧回数
Bio_TICFSL
Hello Steve,
There is no way to debug the console but you add printf to see whats happens for debugging linux you need ARM DS 5 or Lauterbach, Check this link for debugging:
Linux Dynamic Debug
https://community.nxp.com/message/434582
