How to create an encrypted rootfs?
12,582 次查看
trongthinh
I would like to encrypt my rootfs for security purpose. currently, i don't know how to do it. Some documents or suggestion are welcome.
Thank all.
标签 (5)
11,180 次查看
marouene_boubakri
Dear trongthinh‌,
 If you plan to use DM-Crypt to encrypt your RootFS, then,The document "Root filesystem encryption using DM-Crypt" provides detailed steps to make a it.
 The target was ARM64 you can adapt it to your need (Install ARM32 toolchain and compile for ARM target).
If this reply answers your question please mark it as "Correct Answer" so that other users can access it quickly.
Maro
6 回复数
8,795 次查看
Pugo
How can I access the the document "Root filesystem encryption using DM-Crypt"? My organization has a valid NDA and I have the enhanced security status on my profile.
11,181 次查看
marouene_boubakri
Dear trongthinh‌,
Maro
6,624 次查看
saurabhsnair
Dear Maro,
Hope you are doing good!
We are using the IMX6 board for our development purpose. We need the document "Root filesystem encryption using DM-Crypt" urgently. We tried downloading from the link which you shared but we couldn't access it. Kindly share the proper link to the document or attach it to the thread if possible.
Thanks you,
Saurabh
9,960 次查看
ronz
great! thanks for sharing
11,179 次查看
havok31
I am also working on the encryption of the rootfs for an iMX6 board.
 maro: you gave a link to the document"Root filesystem encryption using DM-Crypt" but that file is not accessible ==> I get a "Unauthorized" message.
Is the access voluntarily protected ? Could you tell me what I need to do to be able to download the file ?
regards
11,179 次查看
joanxie
I send some topics from community to you for reference, but for detailed information about security, you need to submit the salesforce case
Is my HAB approach entirely secure?
https://community.nxp.com/message/1083816
