hi Artur Petukhov.
case 1) boot -> onoff button use power off (SNVS_LP Control Register is TOP bit 1 set) -> no automatic power on.
case 2) boot -> "poweroff" linux command use power off (SNVS_LP Control Register is TOP bit 1 set) -> no automatic power on.
case 2) boot -> power adapter remove. power off (SNVS_LP Control Register is TOP bit 1 not set) -> automatic power on.
how I can fix this? I do not need automatic power on. only on off button.
refencence manual please.
I hope it helps. Regards,
Thanks!
