Dear Sir or Madam,
The default code I find ssi1_clk parent is pll3_pfd_508M and clko_clk parent is pll2_528_bus_main_clk that kernel version is 3.0.35. In order to meet the requirements of master I2S , do I need to modify the clock parent?
I don't really understand the difference between the clock, such pll3_pfd_508M and pll2_528_bus_main_clk. Apart from the frequency and frequency of different multiples, what is the difference?
Now I set the parent clk for ssi1_clk and clko_clk to pll4, but I find I can't modify clko_clk and ssi1_clk less than 24mhz no matter how to change pll4 clock.
Do you have any known ways to achieve this?
Thanks.
