How to config ecspi1 clock?
1,917 次查看
jeffery
Now we have developped ecspi driver in imx.6d using qnx platform,but ecspi1 clock is disable(set CCM Clock Gating Register 1 (CCM_CCGR1)  bit 1-0 to 0x11).
How to config ecspi1 clock ?Thanks!
1,765 次查看
jeffery
The situation is solved. The main reason is spi clock configuration pin is wrong.
thanks!
1,765 次查看
jimmychan
what bsp are you using?
