As the title, I don't find any code about the signature in the EBOOT, whether I need to prepare one routine called OEMCheckSignature, and then assign it to g_pOEMCheckSignature?
Which BSP are you using? as far as I know the BLCOMMON is just used in MX27 Wince BSP, to store signatures images on NAND. there is no other verify implementation for MX5x or Mx6 BSPs.
