static unsigned mmc_sdio_get_max_clock(struct mmc_card *card)
unsigned max_dtr;
if (mmc_card_highspeed(card)) {
* The SDIO specification doesn't mention how
* the CIS transfer speed register relates to
* high-speed, but it seems that 50 MHz is
* mandatory.
max_dtr = 40000000;//50000000; <-change this
} else {
max_dtr = card->cis.max_dtr;
if (card->type == MMC_TYPE_SD_COMBO)
max_dtr = min(max_dtr, mmc_sd_get_max_clock(card));
return max_dtr;
