How to change root password and create a new squashfs partition to be used by manufacturing tool
1,313 次查看
angus_comber
On my target board running linux, iMX7 Dual, the /etc config items are stored on a squashfs file system.  I want to change the default root password, what is the easiest way to do that?
I am using the manufacturing tool to deploy to the target.
标记 (2)
1,185 次查看
diegoadrian
I do no quite understand your question. However, I think is not possible to change the password with MFGtool, you can change it before building the image.
Hope this can help you.
Diego.
