How to change DDR size from 2g to 1g
831 次查看
gongyaxuan
How to change ddr size from 2g to 1g? At present, it has been modified to show DRAM to 1g under uboot, but it has encountered the problem of kernel crash caused by cma initialization failure in the kernel phase.
What should I change to the kernel to change the ddr size
759 次查看
Dhruvit
I hope you are doing well
As the CMA initialization is failing, one needs to apply changes in "linux,cma"  node in the kernel device tree.
Kindly replace with the below properties for the 'linux,cma' node.
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0 0x10000000>;
linux,cma-default;
Thanks & Regards,
Dhruvit Vasavada
830 次查看
gongyaxuan
I use 93x chip
