How to build android image for imx8 on AArch64 machine host?
1,907 次查看
builinhhh
Hello everybody,
i'm using Jetson Xavier AGX of Nvidia to build android image (android 13) for imx8 qm Mek kit following the "android user's guide". When i run command "lunch mek_8q-userdebug", i saw an error "/media/vmc/SSD/android_build/build/blueprint/microfactory/microfactory.bash: line 62: /media/vmc/SSD/android_build/prebuilts/go/linux-x86//bin/go: cannot execute binary file: Exec format error"
It means that my Jetson Xavier AGX incompatible with x86 binary because Jetson Xavier AGX is AArch64.
So what can i do to build android image by Jetson Xavier AGX?
Thank you!
标记 (2)
1,746 次查看
Harvey021
Hi @builinhhh
The host and supported packages and Tools are based on X86. we can't really help this for you.
Harvey
1,747 次查看
Harvey021
Hi @builinhhh
Harvey
1,733 次查看
builinhhh
thank you very much!
1,850 次查看
builinhhh
help me, pleaseee!
