How to boot imx25 with NAND
x10
Hi, All
Is it possible to boot imx25 directly with NAND. If it's possible how to write a XLDR or if the XLDR is available.
The so called directly booting means:
(1) BOOT_MODE[1:0] = 2'b10
(2) BT_MEM_CTL[1:0] = 2'b01    // -> NandFlash
(3) eFuse is NOT blown.
The internal boot (with NAND of course) is now used in my design, which takes about 220ms to go to my initial code after power-up. It's required to reduce the booting time. Is it possible to reduce the booting time by using external (direct) booting with NAND?
It's appreciated for any comments
Cheng Shi
www.emtronix.com
Tags (2)
jimmychan
The i.MX25PDK can boot from NAND. You can take it as your reference.
You can download all the information from this web page.
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX25PDK
jimmychan
