How to add reserved-memory in dts on imx7?
3,749 次查看
ZhijianYe
I want to add reserved-memory in dts on imx7. Would you show me?
标记 (1)
3,728 次查看
joanxie
yes, if you need to change the memory for gpu, you can add "gpumem=xxx" in your uboot command, for more detailed information, pls refer to the document as below:
"https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Memory-Management-on-i-MX6-Android/ta-p/..."
9 回复数
3,712 次查看
ZhijianYe
I mean I will write data in the memory by coding during uboot working, not command.Will the data be clean when uboot quit?
3,747 次查看
ZhijianYe
logo_mem@0xbe000000{
compatible = "logo_mem";
device_type = "memory";
reusable;
reg = <0xbe000000 0x02000000>;
status = "okay";
Is it right? How to make it right and work?
3,742 次查看
joanxie
you need add reserved-memory for what? vpu or gpu?
3,733 次查看
ZhijianYe
For saving a memory that is transmited from uboot to kernel. Will it work?
3,729 次查看
joanxie
3,722 次查看
ZhijianYe
Thanks a lot.
And will the reserved-memory be initialized? I need it to keep the date that is written on uboot.
3,718 次查看
joanxie
I don't know what you mean, uboot command just set the memory size
3,714 次查看
ZhijianYe
I think it will be clean. Is there any other way to save the data?
3,716 次查看
ZhijianYe
I mean I will write data in the memory by coding, not command.Will the data be clean when uboot quit?
