How to add multilanguage support to a Yocto build?
6,486 次查看
giorgiopresciut
Dear NXP Community,
I'm trying to add multilanguage support to a Yocto build. In detail I'm trying to setup a clean UTF-8 environment with the following locale: en_US.UTF8.
I tried several build options, such as for example:
GLIBC_GENERATE_LOCALES="en_GB.UTF-8 en_US.UTF-8"
IMAGE_LINGUAS?="en-gb"
without success. As of now, the content of my /usr/lib/locale folder is:
en_US
en_GB
no .UTF8 variants.
Does anyone has experience with linux/yocto/locales on i.MX6 based platforms?
Thanks in advance for your time
Giorgio
标签 (3)
4,487 次查看
joanxie
I give you a sample for how to add chinese on mx6ul board:
 Modify configuration to support Chinese character set.
    $ source setup-environment imx6ul-build-directory
    $ cd conf
    $ vi local.conf      ;add the following two lines to support Chinese in the end
    GLIBC_GENERATE_LOCALES = "zh_CN.UTF-8 en_GB.UTF-8 en_US.UTF-8"
    IMAGE_LINGUAS ?= "zh-cn"
    $ cd .. && bitbake fsl-image-gui
4,487 次查看
giorgiopresciut
Hi Joan,
I've already tried with those options, no success. Do you know if the support of locales can be affected by the presence/absence of a graphical environment? As of now I'm building a console only image. Are you building with x11?
Fabio
