Hello
I am trying to install Unix Bench into iMX6 Poky Yocto 1.6.2 . I successfully cross compiled Unix Bench source code. But when i run Unix Bench, generated error said these 4 perl modules can not be found:
use POSIX qw(strftime);
use Time::HiRes;
use IO::Handle;
use FindBin;So did i miss some thing while build the system?
Or any way to add these modules into yocto?
已解决! 转到解答。
Hi ark
please check
How can I install missing perl modules on an embedded system? - Stack Overflow
also this can be posted on to meta-fsl-arm mailing list, so that someone familiar with it could try to assist you.
https://lists.yoctoproject.org/listinfo/meta-freescale
Hi ark
please check
