How to add ambient light sensor into Android(6.0) HAL layer
6,945 次查看
aravinthkumarja
Senior Contributor II
Hi All,
How to add new light sensor(ambient light sensor) into Android(6.0) HAL layer.?
without adding to HAL how to test it??
Aravinth
5,606 次查看
aravinthkumarja
Thanks for your guys. i have fixed this issue.
Aravinth
7 回复数
5,606 次查看
karvekar
I have a similar question.
How to add iio:device to imx6 HAL ?
5,606 次查看
aravinthkumarja
Hi Mak,
Added new sensor is big procedure. Can you please explore more about it. What kind of sensor you want to add, chip name, etc.?
Aravinth
5,606 次查看
karvekar
I have imx6 Nitrogen6x_Max board.
Added ALS opt3001 on i2c2.
The driver in the kernel shows up as a iio device under 2-0044.
I can read the values from shell.
But the sensor HAL uses input devices instead.
Question was how to update Sensor HAL to accommodate an iio device ?
5,606 次查看
jasminjose
Did you resolve the issue?
I have similar case:
I am trying to add opt3001(i2c0) HAL support to android oreo.
I am working on i.MX6 variscite som
I have added device driver for opt3001.
aravinthkumarjayaprakasam
5,607 次查看
aravinthkumarja
Aravinth
5,606 次查看
Hi Aravinth
one can refer to common android documentation
input - Android sensors hardware abstraction layer - Stack Overflow
http://www.st.com/content/ccc/resource/technical/document/application_note/09/e5/63/88/10/ac/42/26/D...
5,606 次查看
aravinthkumarja
Thanks for response igor,
My light sensor device comes under iio:device, But right now in imx6 Android Hal layer they searching sensor device only inside /dev/input/
How can i make it for iio:device ??
Aravinth
