How to achieve different sound through the two sound card output at the same time in the Android platform?
1,652件の閲覧回数
fdact
Dear Sir or Madam,
           Our product have two sound card and we want different sound can through the dif card output.
   Now out hw platform is IMX6 and use android system.  We find the default code didn't implement the function.
  Do you know what code needs to modified?
Thanks.
7 返答(返信)
1,534件の閲覧回数
art
First, you have to change the Android HAL according to your hardware configuration. Then, a custom application should be created. For more information, refer to the Android Developer sites:
https://source.android.com/devices/audio/index.html
http://developer.android.com/reference/android/media/package-summary.html
Artur
1,534件の閲覧回数
fdact
   Thanks for your reply. I already modify hal to support second sound card, but now at the same time, there is only one sound card work.
But I need play different audio through HDMI and Speaker simultaneously in android?  Can you give me some advice?
Thanks.
1,534件の閲覧回数
art
Refer to the sites above, they contain all required information.
Artur
1,534件の閲覧回数
fdact
Hi artur,
     I had check the website but android didn't implement our demand. So I  would like to know whether IMX have the function to achieve this?
Thanks.
1,534件の閲覧回数
art
Refer to multi-channel audio feature, described here:
Audio Implementation | Android Open Source Project
Artur
1,534件の閲覧回数
fdact
Hi artur,
   Thanks for your reply. You may not understand our needs. That only one sound card can work at the same time.
1,534件の閲覧回数
art
OK, so, please describe the task in more details. What physical interfaces do you use to play sound?
