How to access OTP registers from kernel?
1,589 次查看
petarbajic
On IMX6 SabreSD, OTP fuse driver provides reading from sys fs files in /sys/fsl-otp/ from user space.
I want to read those data from kernel. I can change fsl_otp.c driver to export read functions to other kernel modules, or have my module access sys fs files in user space. Which option would you recommend? Is there a third way to access those data?
Petar
1,394 次查看
alejandrolozan1
I would export the functions you need from the opt driver to your code in the kernel. I do not know if there is a better way to achieve what you need.
/Alejandro
1,395 次查看
alejandrolozan1
/Alejandro
