How to access JTAG in imx8
6,803 次查看
roopeshpookandy
How to access JTAG on IMX8M. What can be used as IDE and what hardware is required in between JTAG and the IDE?
Is there a tool available from nxp?
6,530 次查看
fatalfeel
Contributor V
jtag openocd eclipse
see the imx8m.cfg setting will give you answer
ver 0.10.1 test compile ok on ubuntu 16.04 x64
made on march 2020
https://fatalfeel.blogspot.com/2015/12/openocd-with-eclipse-debug-kernel-of.html
opencod
https://github.com/fatalfeel/openocd_integrated
Eclipse Luna 64bits linux ADT + CDT + Openocd on Java8. Extract to /opt/eclipse_luna
http://www.mediafire.com/file/8fb3dsi88j5iru9/eclipse_luna_adt_cdt_openocd.tar.gz
6,530 次查看
igorpadykov
Hi Roopesh
jtag is described in Hardware Guide:
i.MX8M Hardware Developer’s Guide
nxp does not provide tools, one can try for example arm ds5
Debugging the i.MX 8M SOM Using ARM DS-5
