How to Interface the NXP PN7160 NFC Module With the i.MX8M Plus EVK?
2,033 次查看
Niranjan123
I am working with an i.MX8M Plus EVK and planning to integrate the NXP PN7160 NFC controller (using the PN7160 Raspberry Pi HAT: OM29110RPI-B).
regards,
Niranjan
3 回复数
1,971 次查看
danielchen
HI, @Niranjan123
If you are using Android, please refer to below link  ,  it is about porting PN7160 with i.MX8M nano,
https://community.nxp.com/t5/NFC-Knowledge-Base/Porting-PN7160-to-Android-14-on-i-MX8M-Nano-board/ta...
1,945 次查看
Niranjan123
Thank you for the link, but I am not using Android.
My setup is:
  • Board: i.MX8M Plus EVK
  • OS: Linux (Yocto-based Linux BSP from NXP, not Android)
  • NFC Module: PN7160 Raspberry Pi HAT (OM29110RPI-B)
  • Connection: I2C interface from the EVK expansion header to PN7160 HAT pins
My goal is to bring up the PN7160 in a Linux environment, using the NXP PN7160 Linux driver.
Could you please clarify the following for Linux (Yocto) on i.MX8MP EVK:
  1. Does NXP provide a Linux driver (kernel or user-space) for PN7160 that can be used on i.MX applications processors?
  2. If yes, where can I find the recommended
    • device-tree binding
    • required GPIOs (VEN / IRQ)
    • Linux kernel config options
    • sample DTS node for PN7160?
  3. Which I2C bus on the i.MX8MP EVK expansion connector is recommended for connecting external modules like PN7160?
    (There is no Raspberry Pi 40-pin header on this board, so I want to confirm the correct I2C bus.)
  4. Are there any known reference implementations of PN7160 running on an i.MX8M Plus EVK (under Linux)?
Current status on my side:
  • Verified I2C buses available: /dev/i2c-0, /dev/i2c-1, /dev/i2c-2, /dev/i2c-6
  • Expansion header signals checked in schematic
  • Planning to use I2C2 or I2C1 depending on recommended wiring
  • Before wiring PN7160 HAT, I want NXP confirmation on:
    ✔ Correct I2C bus
    ✔ Required voltage levels
    ✔ Required IRQ and VEN GPIO pins
Any guidance for Linux + PN7160 + i.MX8MP would be very helpful.
Thanks!
标记 (1)
1,928 次查看
danielchen
Hi @Niranjan123
Please refer to below PN7160 Linux porting guide,    You can get the Linux driver and device tree information from below porting duide.
%3CLINGO-SUB%20id%3D%22lingo-sub-2232731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%B0%86%E6%81%A9%E6%99%BA%E6%B5%A6%20PN7160%20NFC%20%E6%A8%A1%E5%9D%97%E4%B8%8E%20i.MX8M%20Plus%20EVK%20%E8%BF%9E%E6%8E%A5%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2232731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20%3CSTRONG%3Ei.MX8M%20Plus%20EVK%3C%2FSTRONG%3E%20%E5%B9%B6%E8%AE%A1%E5%88%92%E9%9B%86%E6%88%90%20%3CSTRONG%3ENXP%20PN7160%20NFC%20%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FSTRONG%3E%EF%BC%88%E4%BD%BF%E7%94%A8%20PN7160%20%E6%A0%91%E8%8E%93%E6%B4%BE%20HAT%EF%BC%9AOM29110RPI-B%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3ENiranjan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20Interface%20the%20NXP%20PN7160%20NFC%20Module%20With%20the%20i.MX8M%20Plus%20EVK%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246605%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244755%22%20target%3D%22_blank%22%3E%40Niranjan123%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%AE%89%E5%8D%93%E7%B3%BB%E7%BB%9F%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E4%B8%8B%E9%9D%A2%E7%9A%84%E9%93%BE%E6%8E%A5%EF%BC%8C%E4%BA%86%E8%A7%A3%E5%A6%82%E4%BD%95%E5%B0%86%20PN7160%20%E7%A7%BB%E6%A4%8D%E5%88%B0%20i.MX8M%20nano%20%E4%B8%8A%E3%80%81%20%20%20%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FPorting-PN7160-to-Android-14-on-i-MX8M-Nano-board%2Fta-p%2F2001159%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FPorting-PN7160-to-Android-14-on-i-MX8M-Nano-board%2Fta-p%2F2001159%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20Interface%20the%20NXP%20PN7160%20NFC%20Module%20With%20the%20i.MX8M%20Plus%20EVK%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E9%93%BE%E6%8E%A5%EF%BC%8C%E4%BD%86%E6%88%91%3CSTRONG%3E%E4%BD%BF%E7%94%A8%E7%9A%84%E4%B8%8D%E6%98%AF%E5%AE%89%E5%8D%93%E7%B3%BB%E7%BB%9F%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%98%AF%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E6%9D%BF%EF%BC%9A%3C%2FSTRONG%3Ei.mx8M%20Plus%20EVK%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%EF%BC%9A%3C%2FSTRONG%3E%3CEM%3ELinux%EF%BC%88%E6%9D%A5%E8%87%AA%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%E5%9F%BA%E4%BA%8E%20Yocto%20%E7%9A%84%20Linux%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%EF%BC%8C%E4%B8%8D%E6%98%AF%E5%AE%89%E5%8D%93%EF%BC%89%3C%2FEM%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ENFC%20%E6%A8%A1%E5%9D%97%EF%BC%9A%3C%2FSTRONG%3EPN7160%20Raspberry%20Pi%20HAT%20(OM29110RPI-B)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E8%BF%9E%E6%8E%A5%EF%BC%9A%3C%2FSTRONG%3E%E4%BB%8E%20EVK%20%E6%89%A9%E5%B1%95%E5%A4%B4%E5%88%B0%20PN7160%20HAT%20%E5%BC%95%E8%84%9A%E7%9A%84%20I2C%20%E6%8E%A5%E5%8F%A3%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%88%91%E7%9A%84%E7%9B%AE%E6%A0%87%E6%98%AF%E4%BD%BF%E7%94%A8%E6%81%A9%E6%99%BA%E6%B5%A6%20PN7160%20Linux%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%3CSTRONG%3ELinux%20%E7%8E%AF%E5%A2%83%3C%2FSTRONG%3E%E4%B8%AD%E8%B0%83%E7%94%A8%20PN7160%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-2001562195%22%20id%3D%22toc-hId-2001614806%22%20id%3D%22toc-hId-2001614806%22%3E%3CSTRONG%3E%E8%AF%B7%E6%BE%84%E6%B8%85%20i.MX8MP%20EVK%20%E4%B8%8A%E7%9A%84%20Linux%20(Yocto)%20%E7%9A%84%E4%B8%8B%E5%88%97%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH3%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E6%98%AF%E5%90%A6%E4%B8%BA%20PN7160%20%E6%8F%90%E4%BE%9B%3C%2FSTRONG%3E%E5%8F%AF%E7%94%A8%E4%BA%8E%20i.MX%20%E5%BA%94%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%20Linux%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E5%86%85%E6%A0%B8%E6%88%96%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%EF%BC%89%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E6%8E%A8%E8%8D%90%E7%9A%84%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E8%AE%BE%E5%A4%87%E6%A0%91%E7%BB%91%E5%AE%9A%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%89%80%E9%9C%80%20GPIO%EF%BC%88VEN%20%2F%20IRQ%EF%BC%89%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ELinux%20%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E9%80%89%E9%A1%B9%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EPN7160%20%E7%9A%84%20DTS%20%E8%8A%82%E7%82%B9%E6%A0%B7%E6%9C%AC%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%BB%BA%E8%AE%AE%E5%9C%A8%20%3CSTRONG%3Ei.MX8MP%20EVK%20%E6%89%A9%E5%B1%95%E8%BF%9E%E6%8E%A5%E5%99%A8%E4%B8%8A%E4%BD%BF%E7%94%A8%E5%93%AA%E6%9D%A1%20I2C%20%E6%80%BB%E7%BA%BF%3C%2FSTRONG%3E%E6%9D%A5%E8%BF%9E%E6%8E%A5%20PN7160%20%E7%AD%89%E5%A4%96%E9%83%A8%E6%A8%A1%E5%9D%97%EF%BC%9F%3CBR%20%2F%3E%EF%BC%88%E8%BF%99%E4%B8%AA%E6%9D%BF%E4%B8%8A%E6%B2%A1%E6%9C%89%20Raspberry%20Pi%2040%20%E9%92%88%E6%8E%A5%E5%A4%B4%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E6%83%B3%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E6%AD%A3%E7%A1%AE%E7%9A%84%20I2C%20%E6%80%BB%E7%BA%BF%E3%80%82%EF%BC%89%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%9C%A8%20i.MX8M%20Plus%20EVK%EF%BC%88%E5%9C%A8%20Linux%20%E4%B8%8B%EF%BC%89%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%9A%84%20PN7160%20%E6%9C%89%3CSTRONG%3E%E4%BB%BB%E4%BD%95%E5%B7%B2%E7%9F%A5%E7%9A%84%E5%8F%82%E8%80%83%E5%AE%9E%E7%8E%B0%3C%2FSTRONG%3E%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CH3%20id%3D%22toc-hId-194107732%22%20id%3D%22toc-hId-194160343%22%20id%3D%22toc-hId-194160343%22%3E%3CSTRONG%3E%E6%88%91%E8%BF%99%E8%BE%B9%E7%9A%84%E7%8E%B0%E7%8A%B6%3C%2FSTRONG%3E%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%3E%E7%BB%8F%E8%BF%87%E9%AA%8C%E8%AF%81%E7%9A%84%20I2C%20%E6%80%BB%E7%BA%BF%E5%8F%AF%E7%94%A8%EF%BC%9A%2Fdev%2Fi2c-0%E3%80%81%2Fdev%2Fi2c-1%E3%80%81%2Fdev%2Fi2c-2%E3%80%81%2Fdev%2Fi2c-2%E3%80%81%2Fdev%2Fi2c-6%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%9C%A8%E5%8E%9F%E7%90%86%E5%9B%BE%E4%B8%AD%E6%A3%80%E6%9F%A5%E4%BA%86%E6%89%A9%E5%B1%95%E5%A4%B4%E4%BF%A1%E5%8F%B7%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E8%AE%A1%E5%88%92%E4%BD%BF%E7%94%A8%20I2C2%20%E6%88%96%20I2C1%EF%BC%8C%E5%85%B7%E4%BD%93%E5%8F%96%E5%86%B3%E4%BA%8E%E6%8E%A8%E8%8D%90%E7%9A%84%E5%B8%83%E7%BA%BF%E6%96%B9%E5%BC%8F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%9C%A8%E6%8E%A5%E7%BA%BF%20PN7160%20HAT%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E6%83%B3%E8%AE%A9%20NXP%20%E7%A1%AE%E8%AE%A4%EF%BC%9A%3CBR%20%2F%3E%E2%9C%94%20%E6%AD%A3%E7%A1%AE%E7%9A%84%20I2C%20%E6%80%BB%E7%BA%BF%20%3CBR%20%2F%3E%20%E2%9C%94%20%E6%89%80%E9%9C%80%E7%9A%84%E7%94%B5%E5%8E%8B%E7%AD%89%E7%BA%A7%20%3CBR%20%2F%3E%20%E2%9C%94%20%E6%89%80%E9%9C%80%E7%9A%84%20IRQ%20%E5%92%8C%20VEN%20GPIO%20%E5%BC%95%E8%84%9A%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%9C%89%E5%85%B3%3CSTRONG%3ELinux%20%2B%20PN7160%20%2B%20i.MX8MP%3C%2FSTRONG%3E%E7%9A%84%E4%BB%BB%E4%BD%95%E6%8C%87%E5%AF%BC%E9%83%BD%E5%B0%86%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20Interface%20the%20NXP%20PN7160%20NFC%20Module%20With%20the%20i.MX8M%20Plus%20EVK%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244755%22%20target%3D%22_blank%22%3E%40Niranjan123%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E8%80%83%E4%B8%8B%E9%9D%A2%E7%9A%84%20PN7160%20Linux%20%E7%A7%BB%E6%A4%8D%E6%8C%87%E5%8D%97%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BB%8E%E4%B8%8B%E9%9D%A2%E7%9A%84%E7%A7%BB%E6%A4%8D%E5%B0%8F%E4%BC%99%E5%AD%90%E9%82%A3%E9%87%8C%E8%8E%B7%E5%8F%96%20Linux%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%E8%AE%BE%E5%A4%87%E6%A0%91%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fapplication-note%2FAN13287.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPN7160%20Linux%20%E7%A7%BB%E6%A4%8D%E6%8C%87%E5%8D%97%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E
